Cucina Pizza Oven Stand starts at $1,050!
The Forno Bravo Cucina pizza oven stand is a line of modular stands for any modular pizza oven kit we make. It is a versatile, DIY, wood fired oven base ideal for all our pizza oven kit models.
The Cucina pizza oven stand makes it easy to give any oven a custom, built-in look—without the effort and weight of building a concrete block (CMU) stand. This can save you several days in construction since the steel frame doesn’t have to be stacked and cured like masonry block.
The Cucina pizza oven stand reduces the weight of the overall construction of your built-in ovens by over a thousand pounds! The steel frame and cement board weigh about 400 lbs without any decorative facade or hearth. Plus, the concrete hearth required is less than 2″ thick with 3/8″ rebar as opposed to the standard 3 1/2″ hearth common on masonry wood fired oven bases.
Cucina Pizza Oven Stand Specifications:
- Available in eight (8) sizes;
- Steel bolt-together frame with pan for concrete hearth;
- Pre-cut cement board for hearth pan and side walls.
Cucina Stand Corresponding Pizza Ovens:
| Cucina Model | Drawings | Giardino | Casa | Premio | Artigiano | Pompeii | Toscana |
| 60 | ICS60 | 60 | N/A | N/A | N/A | N/A | N/A |
| 70 | ICS70 | 70 | N/A | N/A | N/A | N/A | N/A |
| 80 | ICS80 | N/A | 80 | N/A | N/A | N/A | 80 |
| 90 | ICS90 | N/A | 90 | N/A | 80 | N/A | 90 |
| 100 | ICS100 | N/A | 100 | N/A | N/A | 90 | 100 |
| 110 | ICS110 | N/A | 110 | 100 | 100 | N/A | 110 |
| 120 | ICS120 | N/A | N/A | 110 | N/A | 110 | N/A |
| 130 | ICS130 | N/A | N/A | 120 | 120 | N/A | N/A |
*Contact the Sales Team at 1.800.407.5119 for assistance when ordering a Cucina Stand for our commercial pizza ovens.
Cucina Pizza Oven Stand Tips:
If you wish to extend the landing, or build a small prep area outside the oven, you can buy a larger Cucina pizza oven stand and pick up extra space. Each size increases the surface area front to back by 4″.
The Cucina wood fired oven base is comprised of a knocked-down metal frame and pre-cut, pre-drilled backer board panels for the exterior. The stand can be assembled in minutes using a standard wrench and screwdriver.
After assembling the Cucina pizza oven stand, the installer adds a 3/8″ rebar grid, pours standard concrete into the pre-formed hearth tray, and lets it cure—and then places the Forno Bravo oven on top. Check out this installation video for assistance.
The wood fired oven base and oven enclosure can be finished in a wide range of materials, including stucco, stone, and brick.
To learn more about pizza ovens, click here.
| Stand | Dimensions | Shop Now |
| Cucina pizza oven stand – 8 sizes | Dimensions: "W x "D x "H | Buy Now |
