The Wood-Fired Blog
How To Control When Your Dough Doubles in Size
Jan 22, 2026
One of the most important lessons in baking is understanding how fermentation works. Time and temperature quietly control nearly everything that happens inside your dough, from rise to flavor to texture. Once you understand this relationship, you gain real control over your baking results.
The Ideal Fermentation Temperature
Most doughs ferment beautifully around 80 degrees Fahrenheit. At this temperature, fermentation happens gradually and predictably. A typical dough will take about two hours to rise and double in size.
But yeast is extremely sensitive to temperature changes.
For every 17 degree increase in temperature, the rate of fermentation doubles.
That means if a dough doubles in size in two hours at 80 degrees, it will double in just one hour at 97 degrees. Move in the opposite direction and the process slows down. Lower the temperature by 17 degrees to around 63 degrees and that same dough now takes four hours to ferment.
What Happens When Dough Gets Cold
Once you reach about 40 degrees, yeast activity nearly stops. The yeast does not die, but it goes dormant. You can refrigerate dough below 40 degrees and hold it for days with very little fermentation taking place.
This is why cold fermentation is such a powerful tool. It allows bakers to pause the process and resume it later without losing control.
Yeast vs Bacteria
Bacteria respond to temperature changes in a similar way, but they work more slowly. The main reason is simple numbers.
A small amount of commercial yeast contains millions of yeast cells. By contrast, a sourdough starter about the size of a softball may contain only a few thousand bacterial organisms. There are wild yeasts and other microorganisms present too, but bacteria are fewer in number and take longer to influence the dough.
Temperature still matters, but their impact unfolds more gradually.
The Baking Triangle
A helpful way to understand fermentation is through what I call the baking triangle.
The three points of the triangle are time, temperature, and ingredients. At the center of the triangle is baking itself.
Any change to one point affects the others. Increase the temperature and you must reduce the time. Change the ingredients and fermentation behaves differently. Everything is connected.
Ingredients and Fermentation Speed
Some ingredients ferment faster than others. Doughs with natural sugars ferment more quickly because yeast can consume those sugars immediately.
When sugars are locked inside starches, as they often are in flour, fermentation depends on enzyme activity to release those sugars first. That process takes time. This is why longer fermentation often leads to better flavor and browning.
The Invisible Drama Inside Dough
All of this activity is happening whether we notice it or not. Inside the dough, microorganisms are working, enzymes are unlocking sugars, and flavor is being built moment by moment.
We are not forcing the process. We are simply creating the environment that allows it to happen.
That is fermentation.
This is part two of understanding how time and temperature affect microorganisms and how they transform simple ingredients into something we love to eat.
I am Peter Reinhardt.
May your crust be crisp and your bread always rise.
Want to see our  our best selling ovens? Click the link below:
Our Best Sellers: 3 Ovens You Can’t Miss
Archives
