Oven Pizza Tools
Forno Bravo Pizza Making Accessories
Commercial-quality stainless steel pizza tools, including:
Professional-grade Pizza Stones.
Wooden and stainless steel pizza peels.
Available individually, or in Home Pizza Making Kits.
Pizza making tools designed for a lifetime of great pizza.
Pizza Making Kit 1
13 5/8″ round, 3/4″ thick professional-grade pizza stone for baking pizza and hearth bread.
A 12″x14″ wooden pizza peel.
A 10″x8″ steel pizza peel.
Everything you need to start baking great pizza at home.
Pizza Making Kit 2
Professional pizza cutter.
16″ stainless steel serving tray.
Pizza Making Kit 3
15″x20″ rectangular, 3/4″ thick professional-grade pizza stone for baking pizza and bread.
Dough cutter.
Pizza server.
Pizza Making Kit 4: The Ultimate
Dough cutter.
Pizza server.
3-pint copper olive oil canister.
Infrared thermometer.
Stainless Steel Pizza Cutter with Plastic Handle
Commercial-quality stainless steel pizza cutter.
Detachable 3.5″ cutting wheel can be sharpened.
High-grade stainless steel blade (head) and a professional grade plastic handle.
Designed to last a lifetime.
Made by Italy’s premier producer of pizza peels and accessories. Pizza Dough Cutter
Commercial-quality pizza dough cutter.
Durable plastic design will not scratch counters or work surfaces.
The same dough cutter used in Italian pizzerias.
Pizza Server
Commercial-quality stainless steel pizza server (6″x10″‘).
Steel Pizza Removing Peel
Commercial-quality small stainless steel pizza peel (10″x8′) for pizza stone baking.
Easily removes cooked pizzas and bread from a pizza peel in a standard oven.
As any pizza chef will tell you; use a wooden peel to place your pizza in the oven and a steel peel to remove it without risking making a mistake to your perfect pizza.
Wooden Pizza Placing Peel
Short Handled Wooden Pizza Peel.
Use for assembling pizzas before sliding them on a rectangular, metal pizza peel for placement in a pizza oven.
Also good for placing pizza or bread directly on your pizza stone.
Manufactured using high grade and well-seasoned lumber.
Pointed on the front and sides.
12″Wx14″ D blade (head) and 8″ handle.
