Tables of Shipping Weights, Dimensions, and Necessary Unloading Equipment for Receiving Your Oven
Thank you for purchasing a Forno Bravo Pizza Oven! To prepare to receive curbside delivery of your oven, please refer to the tables below.
Depending on the size and weight of your oven, it will be delivered to your business or home in 3 ways.
- If your oven crate is under 2,000 Lbs. shipping weight, it will be arriving in a truck with a lift gate for lowering it to the ground. The crate can then be moved with a pallet jack or other means.
- If your oven crate is over 2,000 Lbs., you will need a fork truck and/or unloading dock to remove the crate from the truck. (Please note that different crate sizes require different fork lengths. These lengths are listed below.)
- All ovens weighing more than 5,000 Lbs. (Napoli) will arrive on a flatbed truck and will require a fork truck or crane for unloading and moving into place.
For more information on the process of receiving your oven, Click Here.
Jump to the table for your oven type by clicking on one of these buttons:
Residential: Ovens Kits, Fully Assembled, Bella Ovens
Commercial: Ovens Kits, Factory Assembled, Mobile Ovens
Residential Pizza Oven Kits
| Pizza Oven | Crate Size: WxDxH | Shipping Weight (LBS) | Required Unloading Equipment | Additional Notes |
| Giardino60 | 44x46x34 | 580 | LIFT GATE | Heaviest piece is dome about 200 Lbs |
| Giardino70 | 44x46x34 | 700 | LIFT GATE | Heaviest piece is dome about 250 Lbs |
| Casa2G80 | 45x48x35 | 940 | LIFT GATE | Heaviest piece is front dome piece about 200 Lbs |
| Casa2G90 | 45x52x35 | 1020 | LIFT GATE | Heaviest piece is front dome piece about 200 Lbs |
| Casa2G100 | 45x48x47 | 1300 | LIFT GATE | Heaviest piece is front dome piece about 200 Lbs |
| Casa2G110 | 45x51x47 | 1496 | LIFT GATE | Heaviest piece is front dome piece about 200 Lbs |
| Premio2G100 | 48x54x49 | 1600 | LIFT GATE | Heaviest piece is front dome piece about 300 Lbs |
| Premio2G110 | 49x55x49 | 1842 | LIFT GATE | Heaviest piece is front dome piece about 300 Lbs |
| Premio2G120 | 49x58x50 | 2003 | LIFT GATE | Heaviest piece is front dome piece about 300 Lbs |
| Artigiano80 | 45x45x48 | 903 | LIFT GATE | Dome weighs several hundred pounds, but has rebar handles for lifting |
| Artigiano100 | 52x48x48 | 1120 | LIFT GATE | Dome weighs several hundred pounds, but has rebar handles for lifting |
| Artigiano120 | 60x48x48 | 1305 | LIFT GATE | Dome weighs several hundred pounds, but has rebar handles for lifting |
Residential Fully Assembled Ovens
| Pizza Oven | Crate Size: WxDxH | Shipping Weight (LBS) | Required Unloading Equipment | Additional Notes / Equipment to Mount Oven |
| Andiamo60 | 41x44x83 | 900 | LIFT GATE | Crate is designed with ramp for easy offload. Casters allow rolling oven on smooth / level surface. |
| Andiamo70 | 46x48x83 | 1050 | LIFT GATE | Crate is designed with ramp for easy offload. Casters allow rolling oven on smooth / level surface. |
| Primavera60 | 48x47x69 | 968 | LIFT GATE | Crate designed with ramp allowing pallet jack to move oven. |
| Primavera60 No Stand | 46x49x42 | 900 | LIFT GATE | Two tier pallet allows straps under oven. Requires an engine hoist or similar equipment to install on stand. |
| Primavera70 | 52x51x69 | 1185 | LIFT GATE | Crate designed with ramp allowing pallet jack to move oven. |
| Primavera70 No Stand | 49x50x48 | 1300 | LIFT GATE | Two tier pallet allows straps under oven. Requires an engine hoist or similar equipment to install on stand. |
| Napolino60 | 48x47x75 | 955 | LIFT GATE | Crate designed with ramp allowing pallet jack to move oven. |
| Napolino60 No Stand | 46x49x49 | 950 | LIFT GATE | Two tier pallet allows straps under oven. Requires an engine hoist or similar equipment to install on stand. |
| Napolino70 | 52x51x75 | 1200 | LIFT GATE | Crate designed with ramp allowing pallet jack to move oven. |
| Napolino70 No Stand | 49x50x49 | 1299 | LIFT GATE | Two tier pallet allows straps under oven. Requires an engine hoist or similar equipment to install on stand. |
| Toscana80D | 51x68x64 | 2612 | FORK TRUCK WITH 48” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana90D | 57x71x64 | 2660 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana100D | 59x75x64 | 3245 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana110D | 62x79x64 | 3750 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana80G | 51x68x71 | 2700 | FORK TRUCK WITH 48” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana90G | 57x71x71 | 3100 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana100G | 59x75x71 | 3400 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana110G | 62x79x71 | 3800 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana80H | 51x68x71 | 2850 | FORK TRUCK WITH 48” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana90H | 57x71x71 | 3560 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana100H | 59x75x71 | 3650 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Toscana110H | 62x79x71 | 4050 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Vesuvio 80 | 59x63x84 | 2300 | FORK TRUCK WITH 48” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Vesuvio 80 No Stand | 59x63x72 | 2667 | FORK TRUCK WITH 48” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Vesuvio 90 | 63x67x84 | 2625 | FORK TRUCK WITH 48” FORKS | Two tier pallet allows straps under oven. Requires fork lift or crane to set oven on stand. |
| Vesuvio 90 No Stand | 63x67x72 | 2965 | FORK TRUCK WITH 48” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Vesuvio 100 | 67x71x84 | 2895 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Requires fork lift or crane to set oven on stand. |
| Vesuvio 100 No Stand | 67x71x72 | 3025 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
| Vesuvio 110 | 71x75x84 | 3550 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Requires fork lift or crane to set oven on stand. |
| Vesuvio 110 No Stand | 71x75x72 | 3665 | FORK TRUCK WITH 72” FORKS | Two tier pallet allows straps under oven. Fork lift or crane required to install oven. |
Bella Stainless Steel Pizza Ovens
| Medio28 with Cart | 41x39x41 | 411 | LIFT GATE | Two person lift to install oven on cart or countertop. |
| Grande32 with Cart | 45x41x41 | 496 | LIFT GATE | Two person lift to install oven on cart or countertop. |
| Grande36 with Cart | 49x43x41 | 558 | LIFT GATE | Four person lift to install oven on cart or countertop. |
| Ultra 40 with Cart | 45x53x41 | 612 | LIFT GATE | Four person lift to install oven on cart or countertop. |
| Medio28 – Countertop | 41x39x41 | 362 | LIFT GATE | Two person lift to install oven on cart or countertop. |
| Grande32 – Countertop | 45x41x41 | 445 | LIFT GATE | Two person lift to install oven on cart or countertop. |
| Grande36 – Countertop | 49x43x41 | 497 | LIFT GATE | Four person lift to install oven on cart or countertop. |
| Ultra40 – Countertop | 45x53x41 | 542 | LIFT GATE | Four person lift to install oven on cart or countertop. |
| Professionale110 Kit | 48x54x62 | 2120 | LIFT GATE | Heaviest piece is front dome piece about 300 Lbs |
| Professionale120 Kit | 48x54x62 | 2306 | LIFT GATE | Heaviest piece is front dome piece about 300 Lbs |
| Modena2G120 Kit | 55x57x63 | 2820 | FORK TRUCK WITH 48” FORKS | Heaviest piece is front dome piece about 300 Lbs |
| Modena2G140 Kit | 58x60x67 | 3315 | FORK TRUCK WITH 48” FORKS | Heaviest piece is front dome piece about 300 Lbs |
| Modena2G160 Kit | 58x60x70 | 3835 | FORK TRUCK WITH 48” FORKS | Heaviest piece is front dome piece about 300 Lbs |
| Modena2G180 Kit | 58x60x70 | 3900 | FORK TRUCK WITH 48” FORKS | Heaviest piece is front dome piece about 300 Lbs |
Commercial Factory Assembled Ovens
| Professionale110 FA | 63x75x84 | 3070 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Professionale120 FA | 67x80x84 | 3430 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Roma 110 | 68x75x84 | 3655 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Roma 120 | 77x79x84 | 4233 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Napoli 120 | 73x75x86 | 4690 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Napoli 140 | 81x83x86 | 5740 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Modena2G120 FA | 67x77x85 | 3720 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Modena2G140 FA | 79x84x84 | 3830 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Modena2G160 FA | 81x92x84 | 3950 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Modena2G180 FA | 81x99x84 | 5470 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on stand. |
| Napoli 120 – Countertop | 73x75x86 | 6413 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on counter. |
| Napoli 140 – Countertop | 81x83x66 | 7054 | FORK TRUCK WITH 72” FORKS | Requires fork lift to install on counter. |
Mobile Pizza Ovens
| Professionale110 TE | 63x75x84 | 1770 | LIFT GATE | Heaviest piece is front dome piece about 200 Lbs |
| Professionale120 TE | 67x80x84 | 1970 | LIFT GATE | Heaviest piece is front dome piece about 200 Lbs |
| Viaggio100D | 60x65x54 | 2100 | FORK TRUCK WITH 48″ FORKS | Requires fork lift to install on trailer / food truck. |
| Viaggio110D | 70x82x50 | 3108 | FORK TRUCK WITH 48″ FORKS | Requires fork lift to install on trailer / food truck. |
| Viaggio120D | 74x82x50 | 3389 | FORK TRUCK WITH 48″ FORKS | Requires fork lift to install on trailer / food truck. |
