Classic Pizza Dough, Neo-Neapolitan-Style
Classic Pizza Dough, Neo-Neapolitan Style
(Makes five 8-ounce pizzas)
What makes this Neo-Neapolitan is that I use American bread flour instead of Italian -00- flour, but you can certainly use Italian flour, such as Caputo, if you want to make an authentic Napoletana dough. Just cut back on the water by about 2 ounces, since Italian flour does not absorb as much as the higher protein American flour. Always use unbleached flour for better flavor but, if you only have bleached flour it will still work even if it doesn’t taste quite as good. If you want to make it more like a New Haven-style dough (or like Totonno’s or other coal-oven pizzerias), add 1 tablespoon of sugar or honey and 2 tablespoons of olive oil. These are optional–the dough is great with or without them. As with the Country Dough, the key is to make it wet enough so that the cornicione (the edge or crown) really puffs in the oven.
Neo-Neopalitan dough in proofing trays
5 1/4 cups (24 ounces by weight) unbleached bread flour
2 teaspoons (0.5 oz.) kosher salt
1 1/4 teaspoons (0.14 oz.) instant yeast (or 1 1/2 teaspoons active dry yeast dissolved in the water)
2 tablespoons (1 oz.) olive oil (optional)
1 tablespoons (1/2 oz.) sugar or honey (optional)
2 1/4 cups (18 oz.) room temperature water (less if using honey or oil)
–You can mix this by hand with a big spoon or in an electric mixer using the paddle (not the dough hook).
–Combine all the ingredients in the bowl and mix for one minute, to form a coarse, sticky dough ball.
–Let the dough rest for five minutes, then mix again for one minute to make a smooth, very tacky ball of dough.
–Transfer the dough to a lightly oiled work surface, rub a little oil on your hands, and fold the dough into a smooth ball. Let it rest on the work surface for 5 minutes and then stretch and fold the dough into a tight ball. Repeat this again, two more times, at 5 minute intervals. Place the dough in a lightly oiled bowl, cover with plastic wrap, and immediately place in the refrigerator. The dough can be used anywhere from 6 hours to three days after it goes in the fridge.
— (Note: the following steps are the same as for the Country Pizza Dough:) When ready to make the pizzas, pull the dough from the refrigerator two hours prior to when you plan to bake. Divide the dough into five 8-ounce pieces (if there is any extra dough divide it evenly among the dough balls). With either oil or flour on your hands, form each piece into a tight dough ball and place on a lightly oiled pan. Mist the dough balls with spray oil and cover loosely with plastic wrap or place the pan inside a large plastic bag. Give the dough at least 90 minutes before making the pizzas. If you don’t plan to use them all, place the extra dough balls inside of an oiled freezer bag and keep in the refrigerator (for up to three days) or in the freezer (for up to three months).
–If using a pizza stone in your home oven, preheat the oven to the highest setting
one hour before you plan to make the pizzas. If using a wood-fired oven, you know what to do for your particular oven. If you do not have a baking stone you can bake the pizzas on a sheet pan.
–Top with your favorite toppings–this dough can be stretched thin (12-13 inches) for Roman-style pizzas, or 10-11-inches for Naples-style.
- Chef Matthew Cutolo, the Link in the Chain
- Ricky Price: “Celebrate Your Wins” and the Five Pillars of Success
- The Most Connected Guy in Pizza, Our Man on the Street, Scott Wiener
- The Quest for the Top Rock Band Singers of All Time, with Guest Peter Scott Ruben
- Team Rose Bread, The Little Cottage Bakery That Could
- Two Chefs and Marketing Guru Walk Into a Bar (or, What the Freak is Pizza Freak: featuring Brad Daniels, Matt McKenney, and Brad Kilgore)
Add Comment
I’m sure this breaks all kinds of “pizza purity” rules…but with this recipie, I have had good luck with spreading a bit of olive oil and salt on the crust and then cooking on parchment paper for a minute BEFORE topping…Then I top the pizza and remove the parchment paper and finish cooking…I have had a GREAT time with this…THANKS PETER!
Great idea and, as far as rules, the only rule I subscribe to is “The Flavor Rule” (in other words, flavor rules!). So, if your technique works, which I’m sure it does to help support the sauce and toppings and retain some bottom crispness, I say go for it!
P.
Why don’t you use the ice water start like in Pain A L’Ancienne in BBA?
Peter, I have used this recipe as written since you first published it. It is a work of art in it’s simplicity,workability and taste. I highly recommend that fellow pizza nuts use toppings sparingly and cook fully to bring out the true beauty of this crust.
du8. One of the problems I have faced is making 5 pizzas for my wife and I to eat in a few day period. What to do, what to do? I at first investigated making full pizzas, albeit underbaked, cooling completely and freezing. Upon recooking, they still tasted like re-heated leftover pizza. I then tried par-baking the crusts as I would a whole pizza, cooling and freezing. This worked slightly better, only I have found that the crust is a bit tougher to the bite.
My solution has been to use what doughs I need the first round, and either make foccaccia, or give the raw dough to my thankful friends.
