You can choose between a Modular Pizza Oven, that you assemble at your home, or an Assembled Pizza Oven, that you set in place and can move later. These questions should help you when choosing a pizza oven that is best for you.
Forno Bravo produces both Modular Oven Kits and Fully Assembled Ovens.
Modular
Do you want a fully custom look for your oven?
Are you incorporating a pizza oven into a new outdoor living space or outdoor kitchen with other appliances, counters and storage?
Do you want to install your oven indoors?
Do you enjoy doing or overseeing the installation process?
Do you have limited access to the area where you are installing your oven?
Our Modular Ovens can be installed in virtually any style and can be easily integrated with other elements of your outdoor space. Plus, each piece can be lifted by a team of two people and carried through a standard doorway or gate.
If yes, then click below to see which modular oven kit is right for you.
NextAssembled
Do you want an oven that you can set in place and start using right away?
Are you uncomfortable doing or managing the installation process?
Have you had trouble finding a local resource to install your oven?
Do you want to take your oven with you when you move?
Our Assembled Ovens are fully insulated, fully assembled and fully finished. You can set them in place and light the fire (be careful to follow the curing instructions). Each of our assembled ovens comes on a rigid platform that can be picked up and moved with a forklift.
If yes, then click below to see which assembled oven is right for you.
Next
