Pizza Ovens | (800) 407-5119 | Info@fornobravo.com
logo
store logo
start shopping button
Home
Order
FB UK
Dealers
Photos
Recipes
Video
Firing Your Oven
Build your fire in the center (left to right and front to back) of the oven using 7-9 sticks of dry kindling, one to two odor-free, non-toxic fire starters, and two to three pieces of seasoned medium or hardwood. Alternatively, you can light your fire with a butane torch. It can be easier and faster than the traditional match or lighter. Try to avoid wax and sawdust fireplace starters, and they could leave a taste in your food.
Once the fire gets going, add 2-3 pieces of wood so that the flame reaches the center and front of the dome, without lapping too far out of the oven opening. Use seasoned wood that is roughly 3’-4’ in diameter, and roughly 18’ long. Your firewood should not smolder or smoke before catching fire, and should burn easily and quickly. Once the fire is well established, continue adding more wood, and wait for about 20 minutes.
After about 20 minutes, a small spot at the top center of the oven dome should start to turn clear (or white), and then begin expanding outward. This "whitening" is the sign that dome is reaching the desired cooking temperature. This change occurs when the carbon accumulated on the oven dome reaches about 700ºF, and turns from black to clear.
The photos show the top of the dome starting to turn clear, then the sides, and finally a completely clear dome, ready for cooking.
Once the whitening has started, begin building the fire toward the walls of the oven by adding pieces of wood on either side of the fire, and in the back. This wider fire will help drive the necessary heat across the entire cooking floor, and evenly spread heat across the cooking dome. Within a few minutes, you will see the whitening spreading across the dome to the sides.
After roughly 45 minutes, the entire cooking dome will turn clear, and the cooking surface will have reached the desired 700ºF for cooking pizza, and you will have saturated your oven with the heat it will need for baking and roasting. You are ready to start baking pizzas, or you can let the oven temperature fall in order to start roasting or baking higher heat appetizers. Alternatively, you can rake out your coals, let your oven temperature moderate, and begin retained heat baking. For more details on different cooking styles, see Chapter 3. Types of Wood-Fired Cooking.
If you will be baking with a fire, or hot coals, you should push the fire to the side of the oven, not to the back. There are two good reasons for this. First, you can see the side of the pizza (or whatever you are cooking) and be ready to turn it when brown. It’s harder to do that when the fire is in the back. Second, your oven will cook better. Wood-fired ovens work by breathing in cold air through the lower part of the oven opening, heating it and circulating it around the oven dome, and then exhausting it out the top of the opening. By putting the fire in the back, you are giving the cold air a longer path before it hits the heat source, which is both cooler, and less likely to create a nice circular convection pattern.
torch
You can use a torch.
start your fire
Enough kindling to light the fire.
dome going white
The dome starting to go white.
fire
The white spot growing.
dome
All clear and ready to bake pizza.
Home | About Us | Our Suppliers | Dealers | Press and News | Contact Us | FAQ | Forno Bravo UK | Shop Forno Bravo
Residential Pizza Ovens | Commercial Pizza Ovens | Catering Pizza Ovens | Pizza Oven Accessories | Pizza Peels | Outdoor Fireplaces
Select | Justify | Order | Install | Manage | Make Pizza | Roast, Bake and Grill
Pompeii Brick Oven | Firenze Concept Oven | Links | Vera Pizza Napoletana | Pizza Oven Photos
Commercial Pizza Oven Selector | Outdoor Kitchen Design | Site Map | Forum
Forum Archive 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
© 2006/7 Forno Bravo, LLC Italian Pizza Ovens
No part of this website or content thereof may be reproduced, distributed or transmitted in any form or by any means, nor may any part of this website be stored in a database or other electronic retrieval system, or any other website, without the prior written permission of Forno Bravo, LLC.
spacer spacer spacer
