Click to Enlarge |
Forno Bravo Pizza Making Family
Commercial-quality stainless steel tools, including:
Professional-grade pizza stones.
Wooden and stainless steel pizza peels.
Available individually, or in Home Pizza Making Kits.
Designed for a lifetime of great pizza.
Click to Enlarge |
Pizza Making Kit 1
13 5/8" round, 3/4" thick professional-grade pizza stone for baking pizza and hearth bread.
A
12"x14" wooden pizza peel.
A
10"x8" steel pizza peel.
Everything you need to start baking great pizza at home.
Click to Enlarge |
Pizza Making Kit 2
A 12"x14" wooden pizza peel.
A 10"x8" steel pizza peel.
Professional pizza cutter.
16" stainless steel serving tray.
Click to Enlarge |
Pizza Making Kit 3
15"x20" rectangular, 3/4" thick professional-grade pizza stone for baking pizza and bread.
Dough cutter.
Pizza server.
Click to Enlarge |
Pizza Making Kit 4: The Ultimate
Dough cutter.
Pizza server.
3 pint copper olive oil canister.
Infrared thermometer.
Stainless Steel Pizza Cutter with Plastic Handle
Commercial-quality stainless steel pizza cutter.
Detachable 3.5" cutting wheel can be sharpened.
High grade stainless steel blade (head) and a professional grade plastic handle.
Designed to last a lifetime.
Made by Italy's premier producer of pizza peels and accessories.
Pizza Dough Cutter
Commercial-quality pizza dough cutter.
Durable plastic design will not scratch counters or work surfaces.
The same dough cutter used in Italian pizzerias.
Pizza Server
Commercial-quality stainless steel pizza server (6"x10"').
Steel Pizza Removing Peel
Commercial-quality small stainless steel pizza peel (10"x8') for pizza stone baking.
Easily removes cooked pizzas and bread from a pizza peel in a standard oven.
As any pizza chef will tell you; use a wooden peel to place your pizza in the oven and a steel peel to remove it without risking making a mistake to your perfect pizza.
Wooden Pizza Placing Peel
Short Handled Wooden Pizza Peel.
Use for assembling pizzas before sliding them on a rectangular, metal pizza peel for placement in a pizza oven.
Also good for placing pizza or bread directly on your pizza stone.
Manufactured using high grade and well seasoned lumber.
Pointed on the front and sides.
12"Wx14"D blade (head) and 8" handle.
Oil Canister
Old-fashioned oil canister for swirling extra virgin olive oil on your pizzas.
Stainless steel interior, copper exterior.
3 pints.
The type of oil canister used by pizzaioli throughout Italy, and described in the Vera Pizza Napoletana specification.
