NY Style Pizza Dough
As we add to our continuing collection of fundamental pizza pantry recipes, I thought it would be important to include one for a New York style pizza dough similar to the ones you get at the many Ray’s pizzerias (none of which seem to be related to each other–Famous Ray’s, Original Ray’s, Ray Ray’s, Not Ray’s–they just keep rolling out), as well as at so many college and family pizzerias across the country. This dough makes a thicker crust than the Neo-Neapolitan dough — such as found at Lombardi’s, Totonno’s, or Frank Pepe’s and Sally’s — and is stronger and less sticky, so it can be stretched and tossed quite easily. If you can get high-gluten flour, such as King Arthur’s Sir Lancelot, that’s the ideal choice. If not, then use unbleached bread flour. Weights are always more accurate than volume scoops, but I’m giving both in case you don’t have a scale. Adjust the flour or water as needed. As with most pizza doughs, it’s better to make this at least 12 to 24 hours ahead, or, it can be held in the cooler for at least three days. You can also make larger size batches if you prefer.
Makes three 12-ounce crusts (for 12″ pizzas), or two 18-ounce crusts (for 15″-16″ pizzas)
5 cups (22.5 ounces) unbleached high gluten flour or unbleached bread flour
1 1/2 tablespoons (1 oz.) honey or 2 tablespoons (1 oz.) sugar
2 teaspoons (0.5 oz.) salt (any kind)
1 1/2 teaspoons (0.18 oz.) instant yeast or 2 teaspoons active dry yeast
3 tablespoons (1.5 oz.) olive or vegetable oil
1 3/4 cups (14 oz.) water, lukewarm
1. In a mixer or a large bowl, combine all the ingredients (if using active dry yeast dissolve it in the lukewarm water first for about a minute before adding it to the dough; instant yeast can be added directly into the flour). Mix on slow speed, or hand knead, for approximately 4 minutes to form a firm, slightly tacky ball of dough. Let the dough rest for 5 minutes and then continue to mix for an additional three minutes on medium speed (or by hand). The dough should be supple and barely tacky. Adjust the flour or water as needed.
2. Put the dough in a lightly oiled bowl, large enough to accommodate it if it doubles in size. Roll the dough in the oiled bowl to coat it, cover the bowl with plastic wrap, and immediately refrigerate it for a minimum of 12 hours.
3. Two hours before you plan to make the pizzas, remove the dough from the refrigerator and divide it into the desired sizes. Form the pieces into tight dough balls, mist them with spray oil, and cover them loosely with plastic wrap (or place them in a covered container).
4. Heat your pizza stone for at least 45-60 minutes, on the highest setting your oven will go. Prepare your toppings, sauce, and cheese. Two hours after you formed the dough balls they should be ready to form and stretch and be turned into pizzas (shorter amount of time on hot days). Set up for your favorite style of pizza, preparing them as seen in the videos, and bake on the stone at the highest setting your oven allows (or put them on a sheet pan and slide it into the oven), for approximately 7 to 9 minutes, or until the pizzas are golden brown on the edges (cornicione), and crisp underneath. Enjoy!!
- Chef Matthew Cutolo, the Link in the Chain
- Ricky Price: “Celebrate Your Wins” and the Five Pillars of Success
- The Most Connected Guy in Pizza, Our Man on the Street, Scott Wiener
- The Quest for the Top Rock Band Singers of All Time, with Guest Peter Scott Ruben
- Team Rose Bread, The Little Cottage Bakery That Could
- Two Chefs and Marketing Guru Walk Into a Bar (or, What the Freak is Pizza Freak: featuring Brad Daniels, Matt McKenney, and Brad Kilgore)
Add Comment
Hi!
Do you HAVE to refrigerate the dough? I don’t have a lot of room in my refrigerator and I was wondering if you could just keep them out (room temperature)?
It really depends on the dough and your game plan. For long fermentation at room temp you will need to reduce the amount of yeast, probably by half or more. But there’s no rule — I use the fridge to give me a larger window to work with. In the end, it’s a balancing act of time/temperature/ingredients — and the permutations are almost endless.
Thank you SO much for this recipe – it is the only one I use now, and I can’t believe the results I get from a crappy cheap electric oven and a pizza stone. I live alone, so what I’ve started doing is dividing the dough into the three 12 oz balls…and then further dividing them so I end up with approx six 6-oz balls. I stretch the dough pretty thin so this ends up being perfect for one meal for me. I freeze them, and put them in the fridge the night before I want to make a pizza. Here’s the question, finally – since they are half the size you mention, should I leave them on the counter half the time? I was guessing that since they are smaller, whatever magic happens may happen in half the time. I’ve started leaving them out only for the hour it takes to heat up my oven, out of impatience and anticipation. Thanks.
Hi Barbara,
Great news regarding the recipe– thanks!! As for your question, they may thaw a little quicker since they are smaller, but you really have a window of about 2 to 3 hours where they won’t do much other than thaw. That said, you may get results after just a 30 minute thaw — hard to say — so I suggest you just start playing with various times and see what works best for you in your situation and with your oven. I would think 1 hour should be sufficient, but, hey, you might be able to bake them while still frozen too — might be worth a try. Please let us know what you discover.
