logo
start shopping button
FB Board Specification Sheet
fb board Description
FB Board is ideal for use as an insulator underneath pizza ovens and brick ovens. It is a high strength, high efficiency Alumina Silicate board originally designed for industrial applications, such as aluminum melting and holding furnaces. One 2" thick layer of FB Board panel reduces the 800ºF cooking floor of a pizza oven to roughly 170ºF at equilibrium, making it roughly twice as efficient as pure Vermiculite board, and even more efficient than castable Vermiculite and Portland cement mixes.
Properties
  • Easy to install and to work with
  • Light weight; easy to ship and handle
  • Easy to cut and glue
  • High compression strength to support pizza ovens and brick ovens
Technical Characteristics
Maximum Service Temperature
2300ºF
Bulk Density (lbs/cu. ft.)
19
Compression strength (Mpa) Thermal Shrinkage 10%
.5
Thermal Conductivity
400ºC
.085
800ºC
.132
1,000ºC
.189
Linear Reheat Shrinkage @ 1000ºC
3%
Chemical Analysis
AL2O3
46%
AL203+SIO2
97%
Fe2O3
<1.0%
Na2O+K2O
<.5%
shop
Back to Installation Equipment
