Pizza Ovens | (800) 407-5119 | Info@fornobravo.com
logo
store logo
start shopping button
Home
Order
FB UK
Dealers
Photos
Recipes
Video
Applying Stucco to the Igloo
Introduction
The oven was assembled, sealed and insulated. It was time to start work on the stucco layer that defines and finishes the Igloo shape. We also started the series of small fires which cure the oven. We were anxious to start cooking, and it was safe to start the process of slowly drying the oven.
So now, I was not only covered with stucco, I smelled like smoke.
Technique
The process of stuccoing the oven uses the wire mesh that is holding the vermiculite concrete to support the first stucco coat. We would be applying a second, smooth coat of finish stucco, so we were not too concerned with the surface of the stucco finish. The last coat would cover that.
Still, we were concerned with the overall shape of the Igloo, and took a lot of care to make sure we liked the shape that was emerging.
The first stucco coat was between 1/2"-3/4".
We applied the stucco using a flat trowel. Starting at the back of the oven and working forward, we applied a series of stucco bands running from bottom to top, running at roughly 45 degrees. This made it easy to fully enclose in the dome and achieve the shape we wanted, without disturbing the insulating concrete.
We were ready to let the oven dry, and to start thinking about the decorative Oven Arch and Landing.
pizza oven stucco layer1. Stucco in an upward angle from bottom to top
pizza oven first stucco layer2. First coat on the oven body
Home | About Us | Our Suppliers | Dealers | Press and News | Contact Us | FAQ | Forno Bravo UK | Shop Forno Bravo
Residential Pizza Ovens | Commercial Pizza Ovens | Catering Pizza Ovens | Pizza Oven Accessories | Pizza Peels | Outdoor Fireplaces
Select | Justify | Order | Install | Manage | Make Pizza | Roast, Bake and Grill
Pompeii Brick Oven | Firenze Concept Oven | Links | Vera Pizza Napoletana | Pizza Oven Photos
Commercial Pizza Oven Selector | Outdoor Kitchen Design | Site Map | Forum
Forum Archive 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
© 2006/7 Forno Bravo, LLC Italian Pizza Ovens
No part of this website or content thereof may be reproduced, distributed or transmitted in any form or by any means, nor may any part of this website be stored in a database or other electronic retrieval system, or any other website, without the prior written permission of Forno Bravo, LLC.
spacer spacer spacer
