Banner Image
Calore2G Modular Outdoor Fireplace Kit
fireplace Forno BravoCalore2G Modular Outdoor Fireplace Kit
Calore Outdoor Fireplace Tile and Rock FinishCalore2G Modular Outdoor Fireplace Kit
The Forno Bravo Calore2G Series is a family of high tech refractory modular outdoor fireplaces. These prefab outdoor fireplace kits are easy to assemble, provide an authentic firebrick interior and can be finished in virtually any material—including stucco, brick and stone. The modular fireplace units feature the innovative Forno Bravo CLICS™ design (Complete, Lightweight, Interlocking Component System), and offer a number of advantages over site-built brick-at-a-time outdoor fireplaces, metal fireplace inserts and other modular masonry fireplace kits.
Unlike a site built (brick and mortar) outdoor fireplace, the Calore2G outdoor fireplace kit does not require any specialized fireplace design or construction skills. Plus, it can be assembled in a fraction of the time required to build a custom fireplace—at a fraction of the cost.
Check out the Calore2G animation to see just how easy it is to build a great outdoor fireplace.
Unlike a metal outdoor fireplace insert, the Calore2G uses real firebricks (9”x4.5”x1.5”) to line a true masonry firebox. The Calore2G not only looks great, it will last for many, many years—and it won’t rust.
The Calore2G prefab outdoor fireplace kit exterior can be finished to meet your own architectural style, matching your outdoor kitchen, or outdoor living room, design—regardless of your specific style. You can design the fireplace with a custom built-in enclosure using either concrete blocks or metal studs and backer panels, and you can apply finish materials directly on the outside of the fireplace.
We offer the Calore2G outdoor fireplace kits in four sizes, (internal opening size finished with firebrick splits): 30″, 36″, 42″ and 48″.
The Calore2G Series outdoor fireplaces are constructed using a high tech insulating refractory composite that is both lightweight and heat resistant to 2600ºF. The fireplace stays cool on the outer walls, while reflecting heat out through the firebox opening. The firebox and vent are designed to promote optimal air flow.
Each Calore2G modular fireplace kit includes the fireplace base, firebox, and chimney.
NOTE: The Calore fireplace kits require a fork lift or loading dock to offload the product. Please plan accordingly when ordering product.
Fast Quote
Fireplace Firebox Opening External Dimensions Shop Now
Calore2G75 Outdoor Fireplace Kit – 30″ Firebox Opening: 30" x 21" External Dimensions: 38"W x 27"D x 75"H Buy Now
Calore2G90 Outdoor Fireplace Kit – 36″ Firebox Opening: 36" x 31.5" External Dimensions: 44"W x 27"D x 86"H Buy Now
Calore2G105 Outdoor Fireplace Kit – 42″ Firebox Opening: 42" x 31.5" External Dimensions: 50"W x 27"D x 86"H Buy Now
Calore2G120 Outdoor Fireplace Kit – 48″ Firebox Opening: 48" x 31.5" External Dimensions: 56"W x 27"D x 98"H Buy Now
What is Insulating Refractory Composite anyway?
Read The Anatomy of the Perfect Outdoor Fireplace to learn more about the Calore2G design.
Compare the Calore2G with Fireplace Kits from other Suppliers.
Can’t decide? Check out our 10 Good Reasons to Pick the Calore2G.
Looking for inspiration? Check out Forno Bravo Photos—there are hundreds of photos full of great ideas.
