Pizza Ovens | (800) 407-5119 | Info@fornobravo.com
logo
store logo
start shopping button
Home
Order
FB UK
Dealers
Photos
Recipes
Video
Refractory Vent and Chimney Manifold
You might have wondered why our Casa and Premio ovens come with a refractory concrete vent and chimney manifold, while some prefabricated ovens come with a steel vent.
There are a number of important advantages to using a refractory concrete vent with a prefabricated oven. Because the vent in these ovens is integrated with the body of the oven chamber, this area becomes very hot. When you first fire your oven, flame can reach into your vent, and as your oven dome heats, it transfers a great deal of heat to the vent.
Over time, this heat will wear out a metal vent, resulting in serious and expensive oven repairs. There is really only one reason for an oven company to use a steel vent with a prefabricated oven -- it is less expensive for the company to build it that way.
Additionally, the refractory vent is easier and safer to install, as it does not require drilling into your oven chamber and bonding the vent in place.
Our refractory vent and chimney manifold are another reason why our ovens are recognized as the quality leaders in the Italian market.
Note that this is not an issue with the Naples-style Artigiano brick oven, where the vent is not integral to the oven body, but rather attached to the oven housing. The Casa/Premio and Artigiano are examples of two different Italian oven and venting styles.
The Casa vent and chimney manifold
The Premio arch/vent, landing and chimney manifold
Some Advantages
Longevity -- the refractory vent and chimney manifold will last as long as your oven, unlike the metal vent that will wear out, and have to be replaced.
Ease of installation -- the vent, chimney manifold and section chimney system are installed using refractory mortar, and do not require that you drill into your oven and set complicated concrete bolts.
Security -- you don't run the risk of drilling into your oven chamber to set a steel vent, and you don't have a metal bolt heating up inside your oven chamber body.
Home | About Us | Our Suppliers | Dealers | Press and News | Contact Us | FAQ | Forno Bravo UK | Shop Forno Bravo
Residential Pizza Ovens | Commercial Pizza Ovens | Catering Pizza Ovens | Pizza Oven Accessories | Pizza Peels | Outdoor Fireplaces
Select | Justify | Order | Install | Manage | Make Pizza | Roast, Bake and Grill
Pompeii Brick Oven | Firenze Concept Oven | Links | Vera Pizza Napoletana | Pizza Oven Photos
Commercial Pizza Oven Selector | Outdoor Kitchen Design | Site Map | Forum
Forum Archive 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
© 2006/7 Forno Bravo, LLC Italian Pizza Ovens
No part of this website or content thereof may be reproduced, distributed or transmitted in any form or by any means, nor may any part of this website be stored in a database or other electronic retrieval system, or any other website, without the prior written permission of Forno Bravo, LLC.
spacer spacer spacer
