Pizza Ovens | (800) 407-5119 | Info@fornobravo.com
logo
store logo
start shopping button
Home
Order
FB UK
Dealers
Photos
Recipes
Video
Sealing the Pizza Oven Dome
Seal your oven in two steps. First, seal each joint, within the oven dome, between the oven dome and the insulating hearth and between the oven dome, vent and arch with refractory mortar. Optionally, you can cover the entire dome with additional refractory mortar.
Sealing the Joints
Water each joint using a sponge, then seal the oven joints by applying a 2"H x 4"W strip of refractory mortar cross the outside of the seam. Do not put mortar inside the joint as thermal expansion could cause the oven to crack.
Seal the oven dome to the insulating hearth with a 2"W x 4"H strip of refractory mortar, the seal the oven dome to the vent and arch.
Additional Thermal Mass
You can optionally increase the thermal mass and heat holding capability of your oven by adding an extra layer of refractory mortar. The optional refractory coating will help the oven hold heat for extended baking and roasting. The addition mass costs a little more, and makes the oven heat up a little more slowly , and is not necessary if you will be using your oven primarily for pizza, fire-in-the-oven cooking and baking single batches of bread.
Both methods are widely used for residential oven installation, and whether you add the additional mortar depends on how you will use your oven, and your views on installation cost and installation time.
Residential ovens can be covered with an additional 1/2" - 1" layer of refractory mortar around the entire oven.
Commercial ovens should be covered with a 2" layer. Additionally, we recommend that Commercial ovens, which are large and made up of more dome pieces, incorporate a layer of wire mesh set half way in the refractory thermal layer for additional reinforcement.
Your are now ready to Insulate Your Oven .
Back to the Table of Contents.
pizza oven dome sealingGraphic 1. Seal the joints with refractory mortar and optionally cover the oven chamber with additional refractory mortar.
Home | About Us | Our Suppliers | Dealers | Press and News | Contact Us | FAQ | Forno Bravo UK | Shop Forno Bravo
Residential Pizza Ovens | Commercial Pizza Ovens | Catering Pizza Ovens | Pizza Oven Accessories | Pizza Peels | Outdoor Fireplaces
Select | Justify | Order | Install | Manage | Make Pizza | Roast, Bake and Grill
Pompeii Brick Oven | Firenze Concept Oven | Links | Vera Pizza Napoletana | Pizza Oven Photos
Commercial Pizza Oven Selector | Outdoor Kitchen Design | Site Map | Forum
Forum Archive 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
© 2006/7 Forno Bravo, LLC Italian Pizza Ovens
No part of this website or content thereof may be reproduced, distributed or transmitted in any form or by any means, nor may any part of this website be stored in a database or other electronic retrieval system, or any other website, without the prior written permission of Forno Bravo, LLC.
spacer spacer spacer
