logo
start shopping button
FB Blanket Specification Sheet
fb_blanket
Description
FB Blanket is the perfect oven dome insulator. It is a flexible woven ceramic blanket that is both highly efficient and easy to install. An Alumina Silicate product originally designed for industrial applications, such as aluminum melting and holding furnaces, the cost of FB Board has fallen to where it is often used as the only dome insulator, making vermiculite obsolete. A 3 " thick layer of FB Blanket reduces the potential 800ºF exterior of a pizza oven dome to roughly 170ºF at equilibrium.
Each Forno Bravo oven comes with 50 sq. ft. of FB Blanket, enough to cover the oven with at least a 1" thick layer. To calculate how much additional FB Blanket you will need to complete your installation, read our FB Blanket Calculation page.
Properties
  • Easy to install and to work with
  • Light weight
  • Easy to cut
  • High efficiency for pizza oven performance.
Technical Characteristics
Maximum Service Temperature
2300ºF
Bulk Density (lbs/cu. ft.)
8
Tensile strength (Mpa) Thermal Shrinkage 10%
.08-.12
Thermal Conductivity
400ºC
.09
800ºC
.176
Linear Reheat Shrinkage @ 1000ºC
3%
Chemical Analysis
AL2O3
46%
AL203+SIO2
97%
Fe2O3
<1.0%
Na2O+K2O
<.5%
shop
Back to Installation Equipment
