web analytics
Metal Fabrication Adelaide Area - Forno Bravo Forum: The Wood-Fired Oven Community
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • Metal Fabrication Adelaide Area
    Hi, I would like to track down a metal fabricator in the Adelaide area (preferably the Hills) to make the front opening arch support. Do any of you other Adelaidians know a good one? Also What is Poorman's mortar?
    Re: Metal Fabrication Adelaide Area
    I believe they gang is talking about what us yanks call Homebrew
    3:1:1:1 sand, fireclay, lime, portland cement. It has been used quite a bit by builders in this forum. I used it in my build. Is it a topic of debate on the forum, just search for Homebrew and you get the answer.
    Link to my Picasa Album
      An arch is self supporting, having steel support anything in a wood oven is fraught with danger.
      My Build.
        Thanks Al.
          Thanks Russell, I'll have a look.
            Hi billkidd,
            to me provided that you do it properly with room for the metal arch support to expand at a different rate than the surrounding refractory brickwork, I see no problems at all as I put in an arch supporting my oven, not to support the arch bricks, but to hinge the cast aluminium doors.
            I have pulled the pictures from my build or you can check them out at:
            the angle iron supports are a loose fit in a wider groove cut into the dome bricks and can move independently without problems.
            Where abouts in the Adelaide hills are you located?
            Almost any handy person with a hammer and welder can make one similar.
            Neillís Pompeiii #1
            Neillís kitchen underway
              dsfgfsdgfdhgdfg dsfdsgfsd
              Fabrication Melbourne
