web analytics
Vermiculite or Perlite - Forno Bravo Forum: The Wood-Fired Oven Community
Forum Issues Update
  • Vermiculite or Perlite
    Im almost ready for insulating layer. What should I use vermiculite or perlite. Someone said that perlite has more insulating value. Is that true? I thought I saw that perlite is cheaper than vermiculite at HD.
    Mike
    Re: Vermiculite or Perlite
    I used half and half. I found it more workable than the straight vermiculite.
    1 part cement to 6 parts vermiculite and 6 parts perlite. Just enough water to make it workable. Mix the water and cement separately then add to the vermiculite / perlite very gently to avoid "breaking down" the particles.
    Make sure you get the coarse perlite.
      I couldn't find vermiculite so I used perlite. It was easy to mix with cement and worked well for insulation. It insulates my oven extremely well.
      My WFO project: http://picasaweb.google.com/stevprin/WFOSmallPhotos#
