web analytics
large brick pizza oven - Forno Bravo Forum: The Wood-Fired Oven Community
Dear forum users,
2) Click Add Photos
5) Click Post
  • large brick pizza oven
    Has anyone tried to build a larger model of the Pompei Oven described on James's site? I'm thinking of a 6' diameter cooking surface with a similar design and my concerns are:
    a) how difficult building dome will be with increased size...
    b) if/how "middle leg" of "W" shaped (instead of "U" shaped) stand was constructed and difficulty involved with blocks over lintel ...
    c) how exhaust through vent/chimney behaves with larger dimensions...
    d) how internal heat of oven is affected by increased size...
    Thanks, Mario
    Support for oven
    Hi Mario--I used a center support going from the front to the rear of the hearth and also going left to right about 2 feet back from the front, which cann't be seen in the photo [ I hope the photo is attached]. I used a quarter inch by 2 inch angle iron to support the blocks over the opening. I've had the oven for about 8 months and there is no hairline cracks on the base. ---Mel
      Thanks Mel. Your oven looks great - good job!
        Mario,
        I can take a stab at #3 and #4. The oven should vent well with a larger chimney without any fans. For example, our Ristorante series ovens come with a 12" round vent opening.
        I terms of heat, you should also be OK. We have Ristorante ovens that go up to 73" -- over six feet. These ovens are able to hold the 750-800F where you tyipcally want to bake pizza.
        Good luck with your project.
        Pizza Ovens
        Outdoor Fireplaces
          Thanks for the input, James.
