web analytics
ash slot - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 2 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
2 of 2 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
ash slot
  • ash slot
    the plans do not call for an ash slot, as the alan scott plans do. i know the pompeii oven is mostly used as a live fire oven, so ashes stay in the oven, and can be removed when cool, but this oven will work great for bread, where hot ash needs to be removed.
    i see no reason why an ash slot cannot be added - please let me know if i am missing something.
    to make it, i plan to block off a section of the framing, and pour the slab around it,so once removed, a hole will be left, forming the ash slot.
    any advice / guidance along these lines?
    Re: ash slot
    There are quite of few postings on the ash slot -- both for and against. :-) If you search they will come up. There is nothing to keep you from adding the ash slot to a Pompeii Oven -- which are often used with only retained heat.
    If you are using insulating board (such as FB Board) rather than vermiculite concrete for under oven insulation, you will want to seal the board as it faces into the ash slot. You do not want ceramic fiber insulation exposed to the inside of your oven -- or anywhere else for that matter.
    If you use vermiculite concrete, then you can just leave that layer exposed.
    Pizza Ovens
    Outdoor Fireplaces
      Re: ash slot
      Don't put the hole dead center - you need that workspace. It's logical to put it on the side that you're going to be building your fire. You can also set in a fireplace ash door, so you won't be loosing stuff down the hole. They are substantial cast iron, so it should hold up.
