web analytics
Chimney Flue Question - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 2 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
2 of 2 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • Chimney Flue Question
    Hello, I've read many of the questions and answers posted on this forum. They have been very helpful as I am in the process of building/assembling my Premio 100.
    I have a quesiton concerning the chimney. I have a fireclay flue and the stanless steel flue. I would like to use the fireclay 13" X 13" and apply stucco directly to the flue. The insulated stainless flue could fit inside the fireclay flue.
    I was wandering if I should use the staneless steel insulated flue inside the fireclay so as to reduce the amount of heat transmited to the fireclay. Thus preventing the heat from damaging the stucco finish I would like to apply to the chimney.
    Is this even necessary? Does the fireclay flue reach temps that will effect the stucco?
    Re: Chimney Flue Question
    The flue gasses leaving your oven are very hot, as is the flue that channel them. I would think that the differential expansion alone would peel the stucco right off an uninsulated flue. Flue tiles are very hard and smooth, I wouldn't think it would take stucco very well even if it remained cool.
    I don't know what kind of stainless flue you have: If it's an insulated chimney system you don't need anything else. Single wall stove pipe is another story.
      Thanks for the reply. That makes sense. I have the insulated stainless pipe.
      I would like to acheive a square or rectangular column effect for the chimney. So I am thinking of using the insulated stainless pipe that will rise through the "hollow", I doubt that is the correct term, of concrete block. I can then stucco the block.
      The vent probably also gets very hot. Therefore I will probably have to have insulation between the top of the vent and the bottom of the first concrete block. Is there a type of insulation made for that sort of situation?
      Would that work or do you have a better suggestion? Again, thanks for your reply!
        What you're thinking of is called a chase. It does not have to be made from something as substantial as block. You could achieve the columnar look by building it out of steel studs, covering the studs with cement board, then adding the veneer treatement of choice: stucco, veneer stone/brick, tile, etc. You don't want to insulate between the pipe and the chase, but you do need an air gap between of two inches or so.
          I think we have a problem in communication. Are you talking about the hollow concrete chimney blocks?
          Those suckers are HEAVY. One person can't lift them. You will need some kind of support other than your dome to hold them up. And yes, they will hold stucco fine.
          They are designed to hold 8 x 8 clay flue tiles, but if the stainless system will fit it, that will be fine too.
            CanuckJim and dnum,
            Thank you both for your replies. That answers my question?
