web analytics
Newby needs help on build - Forno Bravo Forum: The Wood-Fired Oven Community
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • Newby needs help on build
    Hello, my wife purchased a modular brick oven last year (unfortunately not from this site). I am ready to assemble it, but I am not sure of the process. I poured a 4 inch concrete slab for as a counter for it. My questions start with do I pour a vermiculite base now for the whole oven, if so how thick and ratio of vermiculite and cement ? Or do I just pour some vermiculite under the oven only ? Second, do I just assemble the oven then, coat with vermiculite and cemnt mix (thickness & ratio ? ), wrap with insulation blanket, chicken wire, coat agai with vermiculite and cement ?
    I am looking for kind of an idea of the process. I think I know, or atleast I think I know what most of the process will be.
    I also want to note I live in lower NY state ( 60 miles North West of NYC ) it can get a little cold in winter. I already planned on putting a roof over it, is their anything else I should consider.
    Thank You All.
    Re: Newby needs help on build
    My best advice is to start reading.
    There's an e-book and lots of good threads to read through.
    Find a few good threads that you like and read through someones build.
    It sounds like that would help you more than answering a few questions.
    Hope this helps.
    My thread:
    My costs:
    My pics:
      Hi Anthony,
      all the answere to your build will be answered and more in the following link to my Pompeii build. Go to the following and follow it through the different liks to the next threads. It will give you all the answers and hints to undertake your build.
      Neillís Pompeiii #1
      Neillís kitchen underway
        Since you are installing a modular oven, the FB oven installation instructions may be helpful.
          I'm with David,
          Using the Casa installation guide should definitely get you there. We love supporting other company's ovens!
          The vermiculite layer only has to be as large as the oven -- typically 4" of a 5:1 mix of vermiculite to Portland cement.
          Or, you can use FB Board. It is 2" thick and has the same insulating properties as 4" of vermiculite.
          On top of the oven, a 1/2" coating of high heat mortar over the dome is optional (otherwise you seal the joints), followed by either 1" of FB Blanket then 4" of vermiculite, or 3" of FB Blanket. Finally, you need a waterproof enclosure.
          Keep the questions coming.
          Pizza Ovens
          Outdoor Fireplaces
            Somewhere in Rockland county...possibly Orange county? I grew up in that area of the Hudson valley! Lots of great help on this site! Glad to have you?All the best!
