web analytics
Cool Mortar Jig - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 3 < >
Forum Page Loading Response
Forum Members:
We have received feedback regarding recent issues with page loading response time. We believe the slow response issue stems from the analytics we added with the new Forum. We are in the process of reconfiguring those elements and, after an approximate 24-hour time period for the reconfiguration to run, we anticipate a return to normal page load times. Thank you for your patience!
2 of 3 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
3 of 3 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
Cool Mortar Jig
  • Cool Mortar Jig
    As I may have shared before, I am not a good bricklayer. This tool from the UK is a great thing from the look of it, I may have to get one.
    It is a pair of jigs that lay down a perfect bed of mortar between courses of brick, and between individual bricks. The joints come out uniform and level, and there is no waste or dripping of mortar. The mortar joint is already finished when you lay in the brick, there is no scraping of the joint after the fact.
    For those with broadband, there is a video. The spokesman has a really neat accent. Scottish?
    I have no connection to this product, it just seems like a must for masonry. James, you may want to add it to your FB store.
    Pretty Cool,
    I liked the video because it shows what consistency the mortar should be...
    My Oven Thread:
      cool tool
      I saw this tool a few years ago but could not find a local supplier.
      I made my own out of plywood and some fiberglass when I was building several brick piers to hold up a deck. My homemade version worked pretty well. I covered it in fiberglass as the sawn wood edges stuck to the mortar a little too well.
      When I saw the tool on the web, it put a bed of mortar down 3/8 inch or so in from the edge of the brick and I think was advertized as no need (or little need) to tool the joints. I worried that the joints not being tooled would evenually cause leakage. At the website today there is some provision for tooling - if you plan to use a 1/8 inch grapevine jointer you might have problems.
      I went back and make the mortar bed nearly as wide as the brick so that I had some level of squeeze out to tool.
      Where it helped me most was handling mortar, reducing the amount I had to scrape up off the ground and the amount I had to scrub off the face of the bricks - very little to clean up. I was mixing mortar by hand, so I was glad for the increased number of bricks per batch.
      Arch construction may reveal some limitations.....
      For inexperienced guys like me - it works. For 60 dollars I should buy the real deal and get my wife to help!!!!
      My oven progress -
        Yep, pretty cool tool indeed. One proviso, though. You do want to tool or finish point your joints no matter how the bricks are laid. This is less for appearance (except for facade bricks) and more for seal and strength.
