web analytics
Curing - Testing Without Insulation - Forno Bravo Forum: The Wood-Fired Oven Community
Forno Bravo
  • Curing - Testing Without Insulation
    Hi, I'm still fairly new at this, but I thought I'd pass this little experience along in hopes of helping someone else avoid a cracked mortar misadventure.
    I went through the curing process without insulation on my Premio so that I could observe dome looking for cracks, etc. Meanwhile I had already constructed 4" concrete block for the enclosure.
    Near the end of the curing process when temps got pretty high, I noticed some nasty cracks along mortar joints and in a couple of instances actually cracked block. At first, I thought it was due to shoddy construction of the walls.
    Eventually I realized that the cracks appeared in the two areas closest to the dome - the sides. Even though I have about 6" clearance It wasn't enough. I guess insulation doesn’t do much good if you don't use it.
    Oh Well. Live and learn.
    Re: Curing - Testing Without Insulation
    Which block are you referring to. Cracks on the dome/arch are common. If your cracks are not part of the dome, are they of the supporting structure? I'm a little more concerned about that. Photos?
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
      The cracks are in the wall surrounding the dome. When I got to the curing stage 800+ degrees.The heat radiated to 4" block wall clossest to the dome. I shouln't have built the walls until I cured the oven and insulated it.
      The dome is fine. We've been using it every night for about a week. Everyone absolutely loves the pizza and steaks and pork chops and on and on!
        Gotcha. I was worried you meant the supporting stand.
        Mike - Saginaw, MI
        Picasa Web Album
          I think everyone gets some surprises when they build an oven. In my case it is the fact that my chimney should be a bit taller, that the angle iron expands a lot more than I thought it would (and "works" my chimney a bit), and that designing to keep rain out of the guts of the oven is pretty critical. That said, none of it is a big problem, just as your wall block cracks are not likely to be.
          Hang in there and enjoy the pizzas!
          Jay
            Now that you mention chimney, dmun suggested that I distribute most if not all of the weight of the chase bricks to the pad. Is that what you attempted with the angle iron?
            I am attempting to do that by using a 4" I-beam behind the vent supported on both sides by columns of block. I think the beam was a bit of overkill, but I had it available to me for free. This is the best I could come up with.
            I'm not an engineer, but I recon that the vent will be supporting less that 1/2 of the weight. I will build up to the level of the bricks in front and then bridge from front to back with 2.5" cut concrete peices and then build with brick from there.
            I am attempting to attach pictures. I would appreciate any comments or suggestions.
              Wow! Actually cracked the block outside the oven. I understand no inslutaion yet - but you likely had a 4 to 6 inch air gap between the oven dome and your block to allow for insulation. How much air space between the dome and the block that cracked?
              I suppose too, if the motar were fresh between the blocks it could have dried vs. cured....
              As far as the I-beam - I'm pretty certain it will carry most any load related to support a stand alone oven chimney. Pictures or sketches of what you intend to do will surely help.
              Btw - If you want tall chimney Dmun's build has lots of great info - DMuns chimney went clear up the side of his house, so he likely has one of the tallest chimneys on this list.
              Good luck,
              Christo
              My oven progress -
              sigpic
                Right, the mnortar did not have enough time to cure. And to make matters worse, there was mortar debree making contact with the dome and block.
                I tried to attach pictures, but it didn't work for some reason. I'll try again.
                Thanks for the suggestion.
                  QUOTE: dmun suggested that I distribute most if not all of the weight of the chase bricks to the pad. Is that what you attempted with the angle iron?
                  I have an FB oven that includes a door so we built a square opening in front of the oven and used angle iron across the opening (like a square fireplace) to support the front of the chimney. I had the help of a longtime retired mason who had built a few real fireplaces but never a WFO. The expansion of the angle iron is "interesting" but causes no problems - the cracks on the chimney simply open and close. My chimney and base are covered with sandstone and (because of its porous structure) it is probably not the best choice (but it does look good with my property...)
                  Jay
                    Yikes! that was path I was going to head down. It seemed like it would be easier to pack the insulation between the double brick walls after drying out the dome. Thanks for the heads up. I'll be sure that insulation is between the inner and outer brick walls and not expose the outer bricks to such a high heat. Thanks
                    Larry
