web analytics
Begining stand construction - Forno Bravo Forum: The Wood-Fired Oven Community
Forum Issues Update
  • Begining stand construction
    Well I've decided to get started on the stand construction so that I may actually have pizza by the fall when the weather outside is tolerable. Attached are the pictures of the first level for my stand. I decided to locate the oven to the right side of my foundation and utilize the available space on the left to incorporate a brick housing for a grill that I will purchase. Since the grill will have open flames I didn't want it on the right side next to the garage wall. Does anyone see any problem with the oven being that close to the wall? All the flames will be contained inside the oven, and with adequate insulation there should be no significant heat transfered through the housing wall, right? All comments and suggestions welcome. Thanks!
    Oven Progress
    Bread Photos
    Oven Stand Thread
    Re: Begining stand construction
    Hi,
    Some concerns I see are if those are wooden clapboards what about maintenance of them? Secondly the creation of the small space (6"?) between the house and the oven is useless and is going to create a damp space, from the photo it looks this whole area already has issues with moisture? If you cannot connect it to the house (code restriction) Why not either move the oven in the center of the patio or do a corner install at either the yard side or house side? The patio looks to be right at 12" if you move it to the center that gives you 3' on each side, you could incorporate your BBQ and Smoker on the yard side and a counter on the garage side???
    I have to ask, what is the plastic for??
      Originally posted by Unofornaio View Post
      Hi,
      Thanks for comments. The clapboards are actually composite concrete panels made to look like wood. The moisture present is acutally from the daily rain we've had here for the past 3 months. Usually the area is free of any moisture at all. The space on the right side serves a few purposes. One is to center what is to be the complete structure of the oven and smoker/grill. Second, there are little 1/8" tubings (sprinkler lines) that run along the base of the side of the garage that I have to have access to. Third, the channel creates an escape for ground water when it rains. I was going to have the oven centered on the slab before I decided to incorporate the grill. The plastic sheeting is just to create a barrier between the stand and the slab. In the remote case that the oven ever has to be torn down, I'd rather the stand not be cemented to the slab. The visible plastic will be cut away soon.
      Oven Progress
      Bread Photos
      Oven Stand Thread
        Oven stand. Stacked...not mortared. The holes in the back are for any lines (water, electrical, etc.) that ever need to be run. The holes in the front are for the thermocouple meter that I will embed into the stand. If there's anything that doesn't look sound please let me know. Thanks!
        Oven Progress
        Bread Photos
        Oven Stand Thread
          Sounds good to me....
            Decided to do away with the grill, so I centered the oven stand on the slab. This is the first course. I just put the bricks up to see how they would look. The facade will be composed of them.
            Oven Progress
            Bread Photos
            Oven Stand Thread
              You know if you just put some sand (about an inch) in the webs of the first course this will keep the concrete from attaching to the patio. But even if you were to mortar just the first course (to make it level) if you decide to move it the only evidence you'd see on the patio was the stain, the walls would come right off.
              If you are just stacking them because you don't want to try to lay them if your gonna build the dome you might as well start on your laying skills now... besides stucco on the base will cover up a lot of rough work..go for it.. the guys on here can offer advice about laying block for the first time its not that bad a good tip is keep the mud (mortar) on the stiff side blocks are heavy and you'll be pulling your hair out trying to keep them from squishing all the mortar out. On the other hand there is no reason you cant just stack them..as long as the joints are staggered
                Thanks for the tips! Yea I'll acutally be mortaring the first course in about an hour to make everything level. I could probably get by with how it is now, but then remembered how I hate to cut corners when doing stuff...especially something like this where doing it over isn't a viable option.
                Oven Progress
                Bread Photos
                Oven Stand Thread
                  Originally posted by rlf5 View Post
                  .... Does anyone see any problem with the oven being that close to the wall? All the flames will be contained inside the oven, and with adequate insulation there should be no significant heat transfered through the housing wall, right?
                  Sorry for getting in this conversation late, but I'm looking at a potential oven site that is close to a house... but not as close as yours is. My concern is about the chimney. I believe either city regulations or physics suggests the chimney should be 2 feet taller than any structure within 10 feet. For me that would be a 2-story dwelling. I don't want to build a two-story+10-foot chimney.
                  Have you considered the chimney perfomance (or the effect of smoke) being so close to the side of your home?
                    I hear ya..
                    For those ready to take the plunge if the footing slab is WAY out of level in one direction (even up to 2") you can still dry stack the blocks and make this up in the support slab by adjusting the forms. Once the block are covered you will never see it. But if your gonna build the dome Id still recommend "practicing" on the block...
                      For my area 99% of the wind comes from the north so the smoke will always blow away from the house. At least this has been my experience when barbecuing.
                      Oven Progress
                      Bread Photos
                      Oven Stand Thread
                        I hear ya..
                        In my case, it was out of level about 3/4 to 1 inch. I was going to dry stack the blocks, and as you said, make up the difference on the hearth slab. Since I went to the trouble of taking the first stand down I figured I'd might as well get this one level to start with. I just finished it a few minutes ago and it wasn't nearly as tedious as I thought it would be. I got a bit of practice in and I learned that laying mortar in 90 degree weather with 75% humidity is NOT fun. I still have one more block to do though...
                        Oven Progress
                        Bread Photos
                        Oven Stand Thread
                          Looking good....Take a break and go stack the rest of them come on.... you can have the whole base up today. Go Go Go
                          Oh yea the humidity, when I moved out here from PA Id have to say that was a HUGE motivator..In the summer time working with my Dad we would start at first light literally and work till about noon sometimes when it got really bad. Now I'm in Bakersfield where a week of 105 is not at all un common among the other weeks of merely 98-100-02. Something about greener grass comes to mind....
                            Just finished the last block to level on the first course, and then I went ahead and stacked the second course. Two more to go. I'm taking a break in between each course so that should help. I'd go ahead and fill the cores with concrete and rebar today, but the backyard needs to be mowed.
                            Oven Progress
                            Bread Photos
                            Oven Stand Thread
                              I must agree with BrianShaw, I am concerned that the chimney on this will not be up to code...may give you trouble when you try to sell the house. I believe the chimney must be 2' taller than any structure within 10 feet...
                              My Oven Thread:
