web analytics
Weight on Stand - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 2 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
2 of 2 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
Weight on Stand
  • Weight on Stand
    Has anybody calculated the weight of the hearth, dome, insulation, etc., that the stand must support for the Pompeii oven?
    I haven't done it, but I'll bet you could get a close guess by adding the parts. Has anyone thought of working through this?
    Stand blocks
    Floor bricks
    Dome bricks
    Upper walls
    Opening arch
    Pizza Ovens
    Outdoor Fireplaces
      these calculations are based on the materials listed in the plans, as i haven't built my dome or hearth yet. note that the measurements for the hearth are based on a normal cement mix, as i don't have the weight measurements for the insulating concrete mix, and so it will be an overestimate. if anyone else wants to chip in with how much mortar is used in the dome etc., it will answer the question better, but i'd say most of the weight on the stand seems to be from the hearth and dome, unless you finish the walls with stone as well.
      -hearth (69"x76")= 2265#
      -floor and dome bricks=2240#
      -bricks for doorway and decorative arches= 200# (depending on style and type of brick
      -mortar= 60-120#?
      -weight of the upper wall material would vary greatly, but could weigh upwards of another ton, so we'll say 2000# for walls, roof, chimney
      this would put the weight on the stand between 6 and 7 tons.
      overdo it or don't do it at all!
        The vermiculite concrete used in the insulating hearth layer or the outer covering for an igloo finish should weigh in at about 25 pcf.
        One of the big benefits of the Pompeii design over Alan's breadbox style is the elimination of the cladding layer. The cladding on the standard Scott 32x36" rectangular oven weighs just shy of 2,000 pounds. That's why it takes 3 or 4 hours to reach cooking temps. This goes on regardless of the finish technique (gabled house type or igloo).
        My house style finish probably weighed in at a total of 300 lbs for the Durock, metal studs, Ondura roofing tiles and winged gargoyle.
