web analytics
Composite Deck right up to the WFO? - Forno Bravo Forum: The Wood-Fired Oven Community
Forno Bravo
  • Composite Deck right up to the WFO?
    My plan is to construct a deck right up to WFO. I will be using wood joists but composite deck boards. Is there any issue with doing this? If so, can I just put a thin piece of sheet metal over the joists, but below the composite deck?
    http://n8sbar.servebeer.com/
    Oven Thread
    Kitchen/Bar Thread
    Re: Composite Deck right up to the WFO?
    Not quite sure I understand the question. How high is the deck? And the WFO?
    What sort of issues are you worried about?
    My build:
    http://www.fornobravo.com/forum/f6/d...ild-20119.html
      Its a ground level deck. 2x6 sleepers on grond level. I'm pouring the foundation of the wfo to be flush with the deck. My concern is catching the deck on fire.
      Oven Thread
      Kitchen/Bar Thread
        You will drop some coals out of the oven when moving from firing to cooking, but they are minor. Just take care, maybe put a rubber mat down when firing so the coals do not fall in the gaps.
          Or get a hearth rug.
          Old World Stone & Garden
          John Ruskin
            I've had mine up and running for several months, have yet to see any sparks come out the front. Agree with the coals that may drop, and a rubber mat or similar would work well. So would a stone or cement patio right in front of the oven.
            My build:
            My build:
              In this situation I screw down a piece of aluminium checker plate over the decking boards just under and in front of the oven mouth.
                Gudday Davids
                I have a plastic drain running the full length of my oven, the metal ones rust in this climate. Presently use a wet potato sack to cover it when removing ash and coals. That checker plate sounds like a simple and good looking solution to my problem. Thanks Davids
                  I use pine on start up and I have seen pieces pop out 5 foot. I think you will be fine if you use a quality wood and keep an eye on it during start up.
                    the deck itself will be composite, like trex. It won't catch fire but I'll keep it covered to keep it looking nice. That will also protect the joists.
                    Oven Thread
                    Kitchen/Bar Thread
