web analytics
How to secure dome insulation blanket - Forno Bravo Forum: The Wood-Fired Oven Community
Forum Issues Update
  • How to secure dome insulation blanket
    Can anyone tell me how they secured the dome insulation blanket to the dome? Thank you.
    John
    Re: How to secure dome insulation blanket
    I used rebar tie wire. Put a screw into the hearth on either side of my arch, and then ran a loop around the base. Criss-crossed the wire over the dome and arch to secure it. It worked very well - and tie wire is cheap and about the right pliability. $2-3 for a couple hundred feet of it (lifetime supply!)
    My build progress
    My WFO Journal on Facebook
      I set thin wire loops into the dome wall and floor, that way you can thread more thin wire through their loops like a spider web. Thes wires are easy to tighten by grabbing them with the nose of a pair of pliers and giving it a 90 degree twist, to make them sit firm.
        Didn't you know that you can secure anything with "Duct tape"? Everybody knows that!
          I like how threads happen around the time you happen to be near that part of the build. Convenient but freaky.
          Cheers Colin
            I used bird wire and worked my way up just attaching it to itself and then folding the mesh over itself to form the dome shape. It came out a good shape, must have been beginners luck.
            My thinking was I wanted to be able to get some vermicrete behind the wire and this way I was able to do that and get a decent result. Once the vermicrete goes off it all firms up and the render covers the lot.
            Here are a couple of pics of that part of the project. Hope they help.
            Cheers ......... Steve
