web analytics
Final oven coating - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 3 < >
Forum Page Loading Response
Forum Members:
We have received feedback regarding recent issues with page loading response time. We believe the slow response issue stems from the analytics we added with the new Forum. We are in the process of reconfiguring those elements and, after an approximate 24-hour time period for the reconfiguration to run, we anticipate a return to normal page load times. Thank you for your patience!
2 of 3 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
3 of 3 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
Final oven coating
  • Final oven coating
    Can anyone recommend a final coating for my oven installation? I have put a four inch layer of perlite concrete on top of the brick interior and would like to have a more finished outside look. Is their an high heat stucco type mixture i can use?
    Re: Final oven coating
    If you have a high enough perlite to portland ratio, heat should not be an issue for the stucco layer. I will let someone else recomend what type of stuccu to use, since I am not finishing in stucco. Do make sure the Pcrete is dry before going forward though.
    joe watson
    "A year from now, you will wish that you had started today "
    My Picasa Web Album
      Thanks for the reply. The perlcrete will be on 1 week as of saturday I guess i will wing it.
        1 week is most likely not enough to dry it.
          What was your Portland to perlite ratio?
          I also agree that 1 week is not dry enough. A dome style finish is a little risky in Illinois as you do get quite a bit of rain, you will need to take weather precautions when it rains, sleets, or snows. Otherwise you will be drying out your oven alot.
          There are several people with dome style ovens that put vents in to alow for moisture to escape.
            If you have not used blanket, but vermicete instead then take it really slow when driving the water out. because you don't have a blanket to take the sting out of the heat from the dome. If you can bear to leave it for three weeks and make sure it does not get any rain on it. Sun and wind are good but not water. If you see any steam rising from the vermiculite layer back off with the fire. Eliminate as much water as you can before doing the stucco.
