web analytics
Blanket vs loose insulation - Forno Bravo Forum: The Wood-Fired Oven Community
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • Blanket vs loose insulation
    Is it better to use a blanket (HF10, ceramic, etc.) or loose vermiculite. Or should I use both? I currently have a double row of firebrick dome (one laid flat and the outer on its side for a thicknness of about 7 1/2 inches with mortar). Yet I have no heat retention. My oven will not get any hotter than about 500. The floor is a solid row of firebrick laid flat on about 3/8 inch mortar, so about 2 1/2 inches plus mortar. I don't know what else to do but build an outer frame and add insulation over my dome.
    Any other thoughts on why my oven won't get hot?
    Re: Blanket vs loose insulation
    You have a tremendous amount of thermal mass, which means you need a tremendous amount of heat to get it to temperature. You need to insulate the oven. Period. I suggest using ceramic blanket because it is designed specifically to insulate (obviously). You can use loose vermiculite, and the early builders here did so with great success. As material sourcing became easier, most have shifted to blanket over vermiculite. However, there may be cost or sourcing issues that cause you to choose one over the other. You can certainly use both; blanket in contact with the dome and loose fill around it.
