web analytics
Insblock 19 thickness question - Forno Bravo Forum: The Wood-Fired Oven Community
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • Insblock 19 thickness question
    After much searching, I have decided on ANH refractories Insblock 19 and they stock in 1, 1.5 and 2" thickness with 1x3'. All the other ceramic boards would need to be shipped and the cost was 3 times what the Insblock is coming in at $112 that I can pick it up locally.
    Now the question, should I use the 1" and stagger the two layers of boards or just use the 2" boards and let the seams meet wherever.
    Also, if they have the 1.5" boards in stock (I only asked about the 1 and 2" being in stock), should I use two layers that would give me 3" of total insulation. Will that make much of a difference?
    Thanks for you help.
    Re: Insblock 19 thickness question
    I used that product and was able to get it in 4 inch thick pieces. Let the seems meet, I don't think you will lose any efficiency. Here is how I laid it out.
    PhotoPlog - Dome and Floor
      That INSBLOCK 19 is some pretty cool stuff. It’s very rigid and flat. I bought the 3" thick stuff, only because that's what Bill used in his oven and it stays hot for days. I'm right in the middle of my build, but think I would have been better off buying the 1" stuff for my particular build and just layered it up to 3" thickness. If you have the thinner stuff it’s easy to make thick, but if you have the thicker stuff it’s a bit harder to make it thin. Not too much price difference between the thicknesses either. The thicker stuff might be a tad cheaper; I paid ~$100 a box for the 3”. My 2 cents is go with whatever is cheaper to get the thickness you are designing to.
      PS: I was able to negotiate approx. 20% down from the original quote from the ANH salesperson. Doesn't hurt to ask.
        thanks for the tips, I plan on ordering today.
        If I were to use a thermal break on the landing, does this go down into the insulation and how large a gap would you use? Is the gap at the entrance to the landing, or the entrance to the oven?
