web analytics
Help on shaping FB - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 2 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
2 of 2 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
Help on shaping FB
  • Help on shaping FB
    Could some one detail how to shape fire brick?
    I'm referring to a post I saw where the brick
    In arch going into flew had a radious shaped on
    Them... Does one use a belt sander?? But I
    Like the idea of taking off that shoulder to help
    Air flow up the flu.
    Re: Help on shaping FB
    Just use your wet brick saw and take small cuts, you a can use the sides of the blade to feather the cuts although it does wear the blades out quicker. You can use an angle grinder with a diamond cup to do rough removal as well.
    Link to my Picasa Album
      I wouldn't go crazy trying to contour your chimney flue....the flow is sooo slow, it will find its way out around sharp edges etc. Most important is that you have sufficient chimney flue area to accommodate the smoke...otherwise, it will come out the front.
      Where in PA are you located?
        Jeep I'm in Dover township York co
        On the shaping got it. I did read for a 42"
        I want a 8x8 flu.
