web analytics
Stainless steel and masonry/concrete - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 2 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
2 of 2 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • Stainless steel and masonry/concrete
    I want to put a chimney on my outer arch. I don't want to have an exposed SS flue so am planning to "cover" it somehow.
    One idea I have is to enclose it within an outer chimney of, say, vermicrete.
    My question is, can I just shape the vermicrete around the SS flue or will that cause the steel to corrode?
    If ghe concrete will cause corrosion Is there some way of spacing the concrete off the flue?
    Is home brew a better idea than vermicrete?
    Re: Stainless steel and masonry/concrete
    Vermicrete is not particularly strong. On its own it will probably crack. Remember the flue pipe will expand slightly when heated. You would need to encase the vermicrete in something. Ferrocement, brick stone etc. Cement actually inhibits corrosion. If it is stainless you should be ok.
      Thanks David
      I had forgotten how fragile vermicrete is. I was planning to render it like the rest of the oven.
      I guess I will shape home brewed fire clay around the flue and plaster that. Although I suspect that may be a bit heavy
        Yes you can just render over it like the rest of the oven, but give it some strength by using some mesh or chicken wire like a ferrocement boat once you've done that it doesn't matter what happens to the vermicrete because it's trapped inside..
          Thanks again David
          Do you mean tender straight over the steel or use a layer of home brew first?
            No, I mean vermicrete then ferrocement.
