web analytics
Best size for a commercial mobile oven - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 2 < >
Forum Issues Update
2 of 2 < >
Burner Tech Support
Forno Bravo has implemented an on line resource for our Commercial Customers to easily access technical information on their ovens.
Included in this section are the following items:
Type 1 Hood Design
FAQ for Burner Support
Wiring Diagram for your control box
Manuals for many of the component parts
Factory Settings for the Omega Control module
Recommended Spare Parts list
Just follow the link below and you can get their. Of course, you can always call in for support during our normal business hours or create a ticket through our on line support email.
http://www.fornobravo.com/support/in...ercial-support
Thanks for participating in our Forum
  • Best size for a commercial mobile oven
    I would like to put an oven on a trailer or in a truck, what would be the recommended size oven for a small commercial venture, I was originally thinking 90cms (35") but now i am thinking 1100mm (43"). Is there a norm for this application, Thank you
    Re: Best size for a commercial mobile oven
    I think there are so few mobile trucks that a standard does not exist. Add to that the variations of truck size and hauling capabilities... and the decisions get muddy.
    Personally, I don't think going bigger is a bad idea.... just think how many times you've heard somebody say 'i wish it was bigger' versus 'i wish it was smaller'.
    Now, with bigger you will have longer heat up times and more wood,which means more cost, so these are all questions that need to be answered.
    My oven (for now):
    http://www.fornobravo.com/forum/f43/...ven-14269.html
      I have a mobile 40" WFO and we have been using it at our Market Days selling pizzas one weekend a month for the past 6 months...from this experience I would say the biggest challenge is making the pizzas fast enough, more than available floor space to cook them. But, having said that, I think you would be better off with the 43" than the 35" for your mobile commercial operation.
      For me, the 40" is adequate, in fact, I am going to build another one the same size because there are only so many pizzas I can make at a time and manage the oven (4 or 5 pizzas working as fast as I can...stretching and dressing the pizza in under a minute...sometimes 30 second depending on the kind of pizza). It's a juggling act...and very hard work! It is not easy money.
      Also, weight become a big factor in these mobile ovens, my oven weighs 3700 lbs including the single axle trailer (3000 lbs oven alone) and the bigger you get, obviously the heavier it gets. When you add the weight of all the other things it takes to do a mobile operation, you are really talking some weight. I bought a tandem axle trailer for my next oven.
        With that 20% increase in dia. you get 50% increase in cooking surface area. That seems worth while to look into. Can you even get 2 pies in the 35" at one time? Seems with the 35", you can't even try two pizzas at one time. Much bigger than 43" is probably too big for all the reasons david s said.
          Go big as you can on floor space. If your intent is to do some volume, you won't mind the little extra wood or extra weight. I find that extra floor covers a lot of "sins" when under pressure in high volume; you can pick your spot on the floor, absorbs ash you cant get rid of right away (simply push it against the walls), takes additional wood to dry or prep while still baking.
          I run an 81" ID oven I built last winter, (see the thread here somewhere) and having been open 5 months, I couldn't imagine using a smaller oven when we are busy, (though most are, as I can't find mention of a larger one anywhere). I admit that I may sacrifice some fuel efficiency firing a bigger oven, but the payoff comes in high throughput during busy times.
          My mobile oven build will be around 50", with thinner walls and thicker perlcrete cladding with a thinner soapstone hearth.
          Trying to learn what I can about flours, fermentation and flames...
          My 81 inch first build; http://www.fornobravo.com/forum/f37/...ost-11354.html
          My 52 inch mobile; http://www.fornobravo.com/forum/f37/...ing-20874.html
          our FB page; https://www.facebook.com/pages/Artys...20079718042660
            Hi Chris,
            You haven't talked much about the gas burner. Did you fab it yourself? FB just came out with a gas-burner option....so I think it's safe to talk about it. How's it working? Any words of wisdom? I plan to retrofit mine with a gas burner, commercially wood is just too much hassle and my fire-wood source is not very reliable. Plan to make it a combination wood/propane oven. There is a supplier of pizza oven gas burners that I will purchase it from. What do you think?
              We built our own oven and we can cook 28-35 pies a hour. It has a 29" floor and with the gas burner you have more floor space.
              It all depends on if you have to take orders or your are making unlimited pies for a party.
              Chris
                If you want to make up a gas burner you will need a flame failure device and the whole lot should be fitted by a qualified gas fitter.
                  David that is very true... We make ours just like a Turkey Cooker or Crab Pot Cooker... and if I will only make the Pipe for the burner and buy all UL parts..... We had our Plumber that is a Certified Gas Pipe Fitter...... But any Gas Fitter can put the parts together.
                  Dave
                    Please take all discussions of gas ovens off-line. It's the FB position that gas isn't safe for home ovens.
                      Grimaldi
                      How many pizzas would you say you can reasonably make per hour at the fairs?
                        2 mins x one at a time = 30/hr but you need two people working to do it, one to look after the oven and one to prep. Possibly even a third to handle money and orders. A bigger oven that could handle multiple pizzas will need a tandem axle trailer.
                          Thanks for the info. I just need to decide which Forno Bravo oven to get. The lady I spoke with recommneds the Professionale 120 series. Any suggestion?
