web analytics
Heat data - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 3 < >
Forum Page Loading Response
Forum Members:
We have received feedback regarding recent issues with page loading response time. We believe the slow response issue stems from the analytics we added with the new Forum. We are in the process of reconfiguring those elements and, after an approximate 24-hour time period for the reconfiguration to run, we anticipate a return to normal page load times. Thank you for your patience!
2 of 3 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
3 of 3 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
Heat data
  • Heat data
    In the FB (and other) descriptions/instructions it is often referred to the thermal mass of your oven. This mass is crucial for the heat-up time and the baking time (together with a good insulation to reduce heat loss). Practising your oven will of course give you the best procedures and "rules" for these times and the oven temperature.
    For planning purposes the more scientific approach would also be intersting (and possibly helpful?). I know how many bricks (and their mass) my oven dome and floor will consist of and I know (approximately) how much dry mortar I will use. If I knew the specific heats of theses materials (from say 15 C which is the lowest useful for cooking and up to 600 C which is the practical maximum) I would be able to estimate the thermal mass of different design (using more bricks or more mortar). Applying and estimate for heat loss (experience) would also give me an estimate of heat-up and cool-down times. Can someone out there help with the specific heat data?
    regards from Karl
    Re: Heat data
    Not much response to this one! Obviously not in the centre of peoples mind. I have managed to find a value for heat capacity of fire bricks : 1,05 kJ/kg K. No similar luck for dried mortar, but I am sure I can use the same value without to much error.
      Re: Heat data
      What kind of mortar are you using? Depending on its composition, you can have a pretty good difference in heat capacity values. Although, if you plan to have minimal mortar joints, it may turn out to be negligible compared to the bricks. Good luck!
      Oven Progress
      Bread Photos
      Oven Stand Thread
        Re: Heat data
        If it's any help, there's a load of data from my oven here:
        Wlodek's clever with physics, and he was able to do a lot of mathematical stuff with my numbers to tell me the efficiency of my oven's insulation. If anyone could help you, he probably could.
          Re: Heat data
          Thank's Carl,
          I read through the complete discussion in your reference. It did answer a lot of my questions which also were the basis for another issue I have raised in the Forum, - using Siporex blocks for heath insulation. Siporex is the trade name for AAC blocks in Norway. So now I am very comfortable in continuing with my oven on that basis. Unless of course you have had any negative experiences with your oven (AAC experience that is) from last year?
          regards from Karl
            Re: Heat data
            Glad to help. I've had no problem with the AAC yet, but did notice that they get fragile after heating (see my post about my door failure). My oven still seems solid though after a dozen firings or so, but time will tell. If I was building a more expensive oven I'd be tempted to try a layer of insulating board or vermicucrete over the AAC just in case, to protect them from the worst of the heat. They're obviously not a refractory material, but seem to be going strong at the moment.
