web analytics
Build Question - Oven Floor Insulation - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 2 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
2 of 2 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • Build Question - Oven Floor Insulation
    Hi - I am in the process of building a brick oven. The base is concrete block sitting on a slab with footings to the frost line (CT). On top of the block walls I have framed a form for a concrete slab 56"x56"x4". I will pour that slab once I fully understand how to best insluate for the oven floor.
    I have called around locally and can't seem to locate ceramic board insulation...I have read several threads about perlite and vermiculite mixes but still confused over the best method.
    I know I can't just lay the fire brick on the concrete as it will create a heat sink. What is my best option for insulation....if using vermicrete what is the recipe?
    I added a pic so you can see where the build is at this point.
    Re: Build Question - Oven Floor Insulation
    Have you tried searching for foundry supplies, or industrial insulation companies?
    I found a few in your region that should be able to supply rigid insulation as well as ceramic blanketing.
      At this stage of the build, I would recommend that you familiarize yourself with the 'Search' function to locate the information you need. And if you have not done so already, download the FB plans. One particularly good thread is shown below;
      The CalSil Board, FB board or anyother high performing insulation (e.g. Insulating Fire Brick) will be expensive. You can use vermicrete instead or use it to augment the insulating fire brick (more is better) but the vermicrete layer will have to be thicker (~ 2x) to match the performance of the more expensive materials.
      The mix ratio is a bit tricky too. Many people have found success with a 5:1 ratio. I started with this ratio but added lime and a bit more cement to get a nice sticky consistency. However, I was using my mixture for additional insulation on top of my ceramic blanket on the dome - so I wanted a sticky mixture to fight gravity - that shouldn't be an issue with your slab.
      PS. There are more than a few builds on this forum from CT. You might search out those to see if you can get advice on locating materials in your area.
        Thank you for your replies...I will check local foundry suppliers...do some more research on the site...(there is alot of info here...) also see if I can contact some of the local builders to see how they obtained thier materials.
          Most concrete block suppliers will stock perlite or vermiculite since it is used to fill the cavities of CMUs. Check with them, around here in SLC it comes in 4 cubic foot bags abt. 10 bucks a bag. Also try refractory suppliers for CF board and blankets.
          Link to my Picasa Album
