web analytics
What Wood Do You Use? - Forno Bravo Forum: The Wood-Fired Oven Community
Forum Issues Update
  • What Wood Do You Use?
    Obviously this will be a wide ranging question and answer thread, but we are interested. We want to know regardless were you are located.
    In in the North West (Washington state USA). I have many trees around my lot (quite a few now in the wood pile.)
    I have Alder but I think this is better suited to smoking in a BBQ. I have some cedar but that burns hot switch is OK but spits a lot, not OK for cooking in the oven.
    A friend gave me some Cherry but it's not dry enough yet. It's a shame there are no apple trees on the lot.
    So what do YOU use?
    Paul
    Capt. Paul
    Granite Falls WA, USA.
    Oven In Granite Falls
    Re: What Wood Do You Use?
    The best wood is free wood. I love getting wood.
      Paul,
      I use pine to get the fire going (that's pretty much all we have in the high Sierra's). For pizza, I switch to oak or walnut.
        Generally I use Eucalypt which burns very hot and clean.
        Just dropped a huge red gum (1400mm diameter at base) at my son's place and getting it planked and slabbed at the week end, so plenty of firewood for a couple of years.
        http://www.fornobravo.com/forum/f51/...urn-18357.html
        Cheers.
        Neill
        Neillís Pompeiii #1
        Neillís kitchen underway
          My woodpile is growing, love free wood too. Cut down the trees, buck split and stacked them. Lost 15 lbs (Making room for pizza) Take sometime before this is ready to burn however.
          Capt. Paul
            My favorite is Eucalyptus. If properly seasoned it burns clean, hot, and long. And has more BTU's per cord than anything but white oak.
            Second favorite is Oak. That's what I've been burning for the past few months. Not as clean as Euc though.
            Just this week got my hands on two cords of pear and a mixed cord of half oak/half lemon.
            The pear is still wet and won't burn till next year. Haven't had a chance to burn the lemon, but hear that it's good.
            Bill
              You can also buy a box of oak at Smart and Final or any grocery store. For me I love burning oak.
                I can't imagine what the cost of wood would be if purchased at a grocery store by the box. A thousand dollars a cord? More?
                Might be fine for an occasional fire in the fireplace, but to feed a hungry oven on a regular basis, I'd think you'd be better buying in quanity.
                JMO
                Bill
                  Hi Bill
                  Its about $10 for about 15 good size logs but yes its for an occasional use in between getting a cord =)
                    That's actually a lot better than I would have thought.
                    Bill
                      We recommend dry seasoned wood. Around our Monterey Peninsula location, we use oak.
                      We don't recommend anything sappy or you will get too much smoke.
                        Oak. Cured oak (2yrs drying +/-) is probably the best. Oak is what we used in my culinary school's WFO every day to produce bread for the student's and staff's 2 meals a day. As a recovering scientist I would hesitate to use any kind of coniferous (cone bearing and or needled) tree for a WFO. The reason being that coniferous plants produce turpenes (think turpentine) that when heated can break down into something called n-Heptane a highly flammable (good for WFO) and cancer causing (bad for humans) hydrocarbon. Bottom line ingesting it will cause kidney failure...inhaling the gas caused by burning it will cause lung disorders. It may take years of ingesting and inhalation but it will make you sick eventually. no redwood, fir, cedar, pine, juniper, etc. all very bad to burn in a WFO. It won't kill you once or twice, but don't cook with them.
                          Wow Willis thats kind of scary but true...Bottom line better to burn the right wood than get burned with the wrong one!
                            I use 2-3 year seasoned Oak, Ash, Maple, cherry and pear.
                            These racks are now double-wide:
                              That is a LOT of wood - I'll trade you some for a sage bush
