web analytics
smoke from pizza oven - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 2 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
2 of 2 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • smoke from pizza oven
    Does anyone have there pizza oven around 10' from the house I am wondering does the smoke from the oven get in I'm worried about in the summer time when the windows are open will it become a nuisance? I'm just thinking to close may be worse than better. Any regrets?? Anyone??
    Re: smoke from pizza oven
    Smoke at startup is one of the drawbacks of a cross draft flue that the Pompeii incorporates.An updraft system will not smoke out the front unless the chamber is overloaded with fuel. It is possible to fire a front flued oven with no smoke coming out the front if you start with a really small fire underneath the flue, gradually increasing it and pushing it back a little each time you do. in Pompeii the smaller ovens that i saw which were presumably in people's homes were centre flued updraft ones. I think the reason was probably because they did not like smoking up their houses. The large oven at the bakery is different. It utilizes a front flue which retains heat better and presumably fired every day and never got cold.
      My oven is 15 ft from the house and no problem with smoke except the previously mentioned startup. certain wood like walnut or hackberry will give off a little smoke when just starting up but dry oak, maple and elm are not an issue.
      My pool deck is 5 ft above the base of the oven and is less than 5 ft from the pool deck and no problem there either.
      If your oven or wood is wet or sap laden you will not be able to get rid of smoking issues until you fix those issues.
      Check with your property laws 10 ft is not a very large setback make sure you do not get in trouble with the fire department or city hall.
        Mine only smokes during startup but if I am careful even that is minimal. Make sure there is a "solid" flame at all times and add larger pieces of wood slowly. Do not smother the fire with large logs and you will bo OK.
        If I am careful I only get smoke for the first 5 mins until the kindling is burning. Then I slowly add larger pieces , one at a time.
        Once up to temperature there is no smoke.
          Agree with all above, only during start up, you may adjust on windy days that are towards your house, you will appreciate it that close to your house
            I agree with the fisrt few minutes of startup. You can add poplar to the list of smokey woods to avoid. nearly 3 years after taking a truckload of free kiln dried scraps from cabinet shops, I am finally getting rid of the last of it...smokey and nasty smelling to me.
              Mine is just over 10 feet from my back door. It smokes out the front a bit at startup, but never enough to be a bother. Once it gets going, there is no smoke at all.
              My build progress
              My WFO Journal on Facebook
                Poplar is the most evil horrible wood for any WFO - even with a roaring hot fire the moment a fresh, bone dry log of poplar is added horrible acrid black smoke is emitted. It's ok if cut very fine for kindling, but only for getting the fire started and only if a small amount is used. I too learnt this the hard way!!
