web analytics
Outdoor Fireplace or Oven? - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 3 < >
Forum Page Loading Response
Forum Members:
We have received feedback regarding recent issues with page loading response time. We believe the slow response issue stems from the analytics we added with the new Forum. We are in the process of reconfiguring those elements and, after an approximate 24-hour time period for the reconfiguration to run, we anticipate a return to normal page load times. Thank you for your patience!
2 of 3 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
3 of 3 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • Outdoor Fireplace or Oven?
    if you were building an outdoor kitchen and wanted both but could only afford one - which would you go with?
    i realize a lot of this depends on personal preference. I've never had either and am in the process of designing the outdoor kitchen. It will have bar/countertops, sink, fridge, grill, big green egg - and the original intent was to have a fireplace in the corner. I'm just starting to question how often the fireplace would be used - and if it's there primarily for aesthetic purposes would something like a pizza oven accomplish the same thing (in addition to giving me another cooking vessel).
    I guess i'm asking for those that have one/the other/or both, if they have any regrets or wish they could have done it better.
    My apologies if this has been brought up before, i just came across the site and haven't had too much of a chance to dig around (but i've seen enough to know that i'm definitely in the right place and extremely jealous of a lot of the setups i've seen).
    thx for your input!
    Re: Outdoor Fireplace or Oven?
    an outdoor fireplace is merely for aesthics/ambiance. A lot of wasted space, money, and material in my opinion.
    Since you have never had either, build the oven and buy one of those small firepits or chimineas at Home Depot or Lowes.
      I have both. I use the oven 3 or 4 times a month and the fireplace 3 or 4 times a year.
        I have both. It's a no brainer. Go with the WFO. Not only will you benefit from being able to cook amazing pizza and other dishes, you will still get that warmth and aesthetic look you get with a fireplace. Sounds like you're creating a beautiful outdoor kitchen and a WFO will end up being the focal point of it all. I have had mine for 2 years now and use it regularly in spring, summer and fall. I definitely get more use from and compliments on the WFO than the fireplace. Hope this helps. Good luck.
          that's what i was afraid of. i may as well draw up the oven plans along with the divorce papers
            My build (in the initial stages now) will have BOTH!
            I'm building a Steel Dome Oven...
            RIGHT below it will be a wood burning stove with the flu going straight up into the WFO flu transition....
            I can close off the oven with the inner door, put on the outer door and utilize the Fireplace....I hope this makes sense....I'll submit pics once I get to that stage....
            Obviously, one wouldn't use both at the same time....but going from oven to fireplace would take about 10 seconds.....
              If it is only for warmth or ambiance than you might end up regretting a fire place, unless you combine the grill with the fireplace. If you build a fireplace that is big enough to put a grill in that is removable, than when you are done cooking you would remove the grill and though on some wood for the fire. I have seen this done and it works great. That way you can have both. I am building my oven right now and plan on building an open style fireplace for my tuscan grills that I take out or move to have a fire.
                Do the pizza oven, then buy a 50$ fire pit from Walmart for the ambiance!
                  build a wfo with a wide front . splayed out from oven by around 5 inch bigger on the outer part of the entrance and higher , like looking into a funnel .as you look into oven.. then when you finish cooking you can pull your fire forward put some fresh timber on it and its a fire place ,,
                    I built a fireplace in conjunction with my pizza oven which I've used exactly once. Looks great, works like a charm, but why use armloads of perfectly good oven firewood for decorative effect?
