web analytics
Vermiculite Info - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 2 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
2 of 2 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
Vermiculite Info
  • Vermiculite Info
    Is the vermiculite I would use as an insulator, the same stuff you can buy in the lawn and garden deptartment or is it something else. Where can I get it at? Thanks
    Welcome aboard,
    That's it. You can find vermiculite at some Home Depot stores, and at wholesale garden supply stores, in 4 cu. ft. bags. Don't buy it in small bags, or it will add up.
    Here are a couple of useful links:
    For Under Oven insulation, you might want to consider Super Isol, a rigid insulating board.
    Pizza Ovens
    Outdoor Fireplaces
      I found my vermiculite and perlite at a hydroponics supply store. I just finished the insulating hearth today. It took just over four bags ($100) of perlite and about three hours (including start up and clean up) to cover the entire hearth.
      In hindsight, the SuperIsol would have been a better use of my time, but I'm having fun trying to do my first oven as cheaply as possible (but no cheaper).
      I'm building a Pompeii Oven in Austin, Texas. See my progress at:
      Il Forno Fumoso
        I was horified by the first little batch of pearlite concrete I mixed up to go under my fireplace floor. What is this mess, I thought, but it hardened up to a really solid surface. The edges of it don't have any kind of hardness, but they don't fall apart, and it will all be covered up in my plan anyway.
          If Perlite is used, then be sure it is agricultural grade!
          (M) If you decide instead to use Perlite rather than Vermiculite, be sure that the Perlite is agricultural grade. The construction grade is coated with silicon and is *not* what you want. In mixing Perlite as an aggragate, it needs to be able to absorb water!
