web analytics
Help. pre-cast oven plans and concrete recipe. - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 3 < >
Forum Page Loading Response
Forum Members:
We have received feedback regarding recent issues with page loading response time. We believe the slow response issue stems from the analytics we added with the new Forum. We are in the process of reconfiguring those elements and, after an approximate 24-hour time period for the reconfiguration to run, we anticipate a return to normal page load times. Thank you for your patience!
2 of 3 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
3 of 3 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
  • Help. pre-cast oven plans and concrete recipe.
    I want to build an outdoor oven (Pizza) and basically I have spent a while reading the books and studying the internet and had decided to have a go at using bricks and blocks however I have not laid a brick ever but by trade I am a shuttering carpenter (Formwork) so the obvious and easiest thing to do would be to build my own form (Mould)for the dome.
    Concerns I have are, what sort of reinforcement do I use as I guess that steel re-bar would expand with the heat and crack the dome or is this not the case.
    (How are the other pre cast domes manufactured?)
    Does anyone know of any plans for a form to make pre-cast domes and also how do I make refractory concrete?
    Any other info would be greatly appreciated. Thank you
    Precast ovens
    Hello Sonoma,
    Are you in Somona? We're in Healdsburg, where is it predicted to be 106F tomorrow. Ouch. We just got back from the Sierras, where it was a lot nicer (other than swimming in the Stanislaus river where the current was the fastest I've seen -- I almost got swept away).
    You can cast your own oven, and there is even a book on how to make a Cobb (Adobe) oven. Kiko Denzer's, Earth Ovens. I've never done it, nor have I watched anyone do it, so my experience is limited to books and photographs -- and the adobe oven at Preston Vineyards. One downside of adobe ovens is that it really doesn't get hot, like a real pizza oven. I also don't know if they will last.
    If you construct your oven dome using refractory concrete, the oven will perform better than adobe, but you still have the work of building the forms and getting the shape right (you would have to do a lot of cutting and bending to get a good form), pouring (would you do it in layers) and curing the concrete -- and that only gets you the dome. You still need to build the stand, hearth, cooking floor, vent, door, insulation, etc. I am not sure how likely a monolithic concrete dome would be to cracking. Putting lost of metal, such as rebar, would make the cracking worse. Something to think about.
    One thing I have seen in the Mediterranean countryside are stone ovens. Maybe some will build a complete oven from "found" stone.
    I always like to learn from other people's experience, which in this case has shown me zillions of brick ovens.
    Pizza Ovens
    Outdoor Fireplaces
      Re: Help. pre-cast oven plans and concrete recipe.
      Hi ....
      You could use a ply wood shutter for your dome say 5mm ply strips bent onto a light wait ply spar setup which you coul burn after pouring your refractory concrete , there are plenty of conflicting mixes available online but have yet to find a mix that states itself as a fire resistant concrete ..... The shape of the dome should be ok without reinforcing at the sizes needed but good insulation is a must to keep reflecting that all important heat into the cooking chamber
        You are replying to a post that is over 7 years old - may be a little late.
          Ha ha yeah....it took me that long to think of a reply !
