web analytics
Cuchon du lait - Forno Bravo Forum: The Wood-Fired Oven Community
1 of 3 < >
Forum Page Loading Response
Forum Members:
We have received feedback regarding recent issues with page loading response time. We believe the slow response issue stems from the analytics we added with the new Forum. We are in the process of reconfiguring those elements and, after an approximate 24-hour time period for the reconfiguration to run, we anticipate a return to normal page load times. Thank you for your patience!
2 of 3 < >
Hello, Forno Bravo Community Forum members.
As many may have noticed already, the Community Forum site was briefly down today. While working on scheduled routine maintenance, we encountered an error when trying to add a software update. As the site is now back up and running, some of you may notice that some recent data has been misplaced from November 10th up to today. We are currently working on resolving the issue. The forum has full operational capabilities and we encourage all forum members to continue actively posting in the threads.
We apologize for any inconvenience that this issue may have caused you. The Forno Bravo family values each and every member of our community. If you have any issues or concerns, please feel free to let us know on our issues thread here:
Thank you for understanding.
3 of 3 < >
Forno Bravo Forum Thread Message
Hello, Forno Bravo Community Forum Members!
The Forno Bravo team has heard the feedback in regards to the community forum. We wanted to take the time to re-enforce our commitment to a fully engaged Forum with professional moderation.
Our top priority as a company is to fix all forum errors and issues that you are experiencing. As we are swiftly working on these problems, we want to say that we highly value the Forum Bravo Community Forum and every single community forum member.
We have set up this thread so that every member can address any concerns, issues and questions about the forum. Please feel free to ask whatever you would like in regards to the forum; let us know what issues you are experiencing so we can work on resolving them as fast as possible. However, we stress that we would like constructive engagement, so please be specific about the issue you are experiencing.
Thank you for all of your patience and continued support.
Link to topic: http://www.fornobravo.com/community/...with-new-forum
Cuchon du lait
  • Cuchon du lait
    I live in Baton Rouge and am planning an oven to completed by Saint Patrick's day.
    At this time, I am leaning toward a teardrop french design with fairly heavy cladding. This will give me the oven depth to accommodate an entire pig and the door height to deal with a nice big rib roast. Bread and cooking come in second and pizzas have priority #3.
    I will use fire bricks for the floor of the oven, but I want to use solid red clay bricks for the dome. There seems to be some debate on the red clay bricks, but i have seen ovens that are a hundred years of more old with intact red brick vaults and domes. Any informed opinions are welcome and solicited.
    Re: Cuchon du lait
    Sounds interesting. Do you have some drawings you can post so we get the picture?
    How tall do you think the oven door should be to accomodate a pig?
    Lee B.
    DFW area, Texas, USA
    Our One Meter Pompeii Oven album is here.
    An album showing our Thermal Breaks is Here.
      Re: Cuchon du lait
      The Alan Scott and Daniel Wing book "The Bread Builders" says clay bricks are ok for the dome. Most of us use firebricks becuase we are worried about the long term life of the oven, Clay bricks COULD potentially spall or crack after repeated heating and cooling cycles. But after how many? 100? 1,000? 10,000?
      Even if you are adding extra mass, be sure to insulate all around the oven, including under the floor, and expect additional heat up time and fuel consumption.
      How much bread do you expect to cook at once. I have 1" of extra mass on my pompeii dome and have cooked as much as 32 pounds of bread at once and could have baked more...
      My Oven Thread:
        Re: Cuchon du lait
        Baton Rouge/Slidell red commons are fine for the oven. Just make sure they ARE solid commons.
          Re: Cuchon du lait
          Speaking of extra mass, two questions. Do you think your oven would handle 32lbs of bread without the extra 1" of mass? Without the extra mass do you think your oven could handle a second batch (maybe 20lbs and 20lbs)?
          Thanks in advance,
            Re: Cuchon du lait
            Not sure about without the extra mass John, but pretty sure I could do 40 lbs with no trouble.
            My Oven Thread:
