Pizza Ovens | (800) 407-5119 | Info@fornobravo.com
logo
commercial pizza ovens
store logo
Home
Order
Forno Bravo UK
Dealers
Photos
Recipes
Why the Modena Series Ovens are Special
landscape
pizza oven
State-of-the-Art Design
1. Support stand in square tubular steel; stove enamel coating.
2. Steel support platform, reinforced with square tubular steel sections; stove enamel coating.
3. 6’ thick under-oven insulation comprised of a double layer of high-efficiency solid-state refractory insulting tiles, fired at 1700ºF.
4. Monoblock 2 ¾’ cooking floor, made from proprietary high-density, vibrated refractory material.
5. Dome segments between 3’ sides and 4’ top thick, made from proprietary high-density, vibrated refractory material.
6. Oven landing, made from proprietary high-density, vibrated refractory material covered with high-grade stainless steel.
7. Arch, which projects 2’ beyond the oven enclosure allowing for custom partition wall enclosure.
8. Steel enclosure panels with red stove enamel coating; durable, washable and non-rusting.
9. Steel vent, with paint finish capable of withstanding high heat.
10. The joints between the dome sections, and between the oven floor and cooktop are grouted with refractory plastic mortar capable of withstanding 2500ºF.
11. Ceramic fiber dome insulation between 4’-8’ thick; capable of withstanding 2500ºF.
12. Additional loose insulation.
13. Oven door.
Home | About Us | Our Suppliers | Dealers | Press and News | Contact Us | FAQ | Forno Bravo UK | Shop Forno Bravo
Residential Pizza Ovens | Commercial Pizza Ovens | Catering Pizza Ovens | Pizza Oven Accessories | Pizza Peels | Outdoor Fireplaces
Select | Justify | Order | Install | Manage | Make Pizza | Roast, Bake and Grill
Pompeii Brick Oven | Firenze Concept Oven | Links | Vera Pizza Napoletana | Pizza Oven Photos
Commercial Pizza Oven Selector | Outdoor Kitchen Design | Site Map | Forum
Forum Archive 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
© 2006/7 Forno Bravo, LLC Italian Pizza Ovens
No part of this website or content thereof may be reproduced, distributed or transmitted in any form or by any means, nor may any part of this website be stored in a database or other electronic retrieval system, or any other website, without the prior written permission of Forno Bravo, LLC.
spacer spacer spacer
